Sponsored by: CARiD
Leveling kit for 2002 Screw???
Old Jan 21, 2007 | 07:26 PM
BGKFX4's Avatar
Looking for suggestions for a leveling kit for my 2002 Screw? Anyone have suggestions regarding manufacturer or any other suggestions would be greatly appreciated.
Thanks alot!!
Old Jan 21, 2007 | 07:46 PM
wandell's Avatar
If you have a 4x4, you don't need a leveling kit because your front ride height is adjustable via the torsion bar preload. If you have a 4x2, Daystar makes coilspring spacers for your truck.
Old Jan 21, 2007 | 09:22 PM
bassmaster1061's Avatar
wandell (or anyone else), Would there be a big difference between a 1.5" Daystar leveling kit and a 2" Trailmaster Leveling kit? Also, does anyone have a picture of either on a 97-03 4x2?
Old Jan 21, 2007 | 09:39 PM
chiefFX4's Avatar
personal preference but id go daystar. heard only bad things about trailDISASTER suspension products. your coils may have started sagging a little.
Old Jan 21, 2007 | 10:33 PM
Would 285's fit as well with the 1.5" as with the 2" kit?
Old Jan 22, 2007 | 12:32 AM
mlsman23's Avatar
I am having the daystar put on my truck along with spindles, I should be getting my truck back tomorrow (had to wait for shocks to get in) but I will let you know how it goes. If you needs pics let me know. And 285's should fit with both if I remember what wandell told me correctly.
Old Jan 22, 2007 | 07:57 AM
wandell's Avatar
Yeah, 285's should fit easily depending on wheels. I'd use 16x8's.
Old Jan 22, 2007 | 03:55 PM
great thanks
Old Feb 5, 2007 | 10:23 PM
BGKFX4's Avatar
4x4's don't need leveling kits??
So, I can just crank up the preload if I have a 4x4?? I see where the screw are.........Can you explain....Can I just screw the bolt one way or the other to level the truck??? I thought the aftermarket leveling kits were someow made differently???? Please help!! Thanks!!
Old Feb 6, 2007 | 07:53 AM
wandell's Avatar
Right. Tighten each bolt an equal number of turns to raise the front of the truck. You will need an alignment afterwards. The aftermarket torsion bar keys do the same thing. They just allow you to put even more preload on your torsion bars.
