What kind of backspacing?
I have decided to put a 2in leveling kit on my 2006 supcrew fx4. I want to go with aftermarket wheels, and 35's. What size wheels do i need.(lug puttern, back spacing,offset) I really dont know what kind of tires i want to go with. I used to have bfg muds, and i liked them but they are expensive. THANKS for the help.
Your factory wheels should be 7.5" wide with 5.5" of backspacing. Backspacing is measured from the back edge of the wheel to the mounting surface on the wheel where it meets the hub. Aftermarket wheels are 9"+ with something between 4 - 5.5" inches of backspacing. The less the backspacing the more it pushes the wheel out of the wheel well.
A 9" wheel with 4.5" of BS would add 2.5" of tire sticking out beyond factory (9" - 7.5" = 1.5" wider wheel) plus one inch (5.5BS - 4.5BS = 1") plus any additional width from the wider tires.
To simulate the potential for rubbing, I took a 2.5" PVC pipe, cut it to 35", centered it on the outside edge of my tires and turned them. That extra 2.5" was eating up my wheel well, an obviously bad scenario if I would have put wheels on that pushed tires out 2.5" at 35" diameter.
Originally Posted by 06flamefx4
So if using the factory wheels will i rub at all. That is what im really wondered about. I little rubbing here and there isnt a big problem but i dont want the tires getting ate up or my fender wells. Thanks
