Final Lift Questions, need answers please.
Alright here it goes. this is what i have in mind. I want to clear 20" wheels and 36" iroks on my 05 F150 2wd with a 6" pro comp standard lift kit which is installed already. In order to do this i want to add a 2.5" leveling kit ontop of my pro comp 6" lift, and put a 2.5" add a leaf in the rear.
Will this setup work to clear the wheels and tires? will i sit level still, like iam right now? i know its not very good to add the level kit to my suspension lift, but i see some people doing this and not having any problems. Hopefully they will chime in. Also, will i need larger shocks to accomodate the level kit and add a leafs? and how about the u-bolts for the rear, i have a 4inch + 2 inch block in the rear right now, can i use the same u-bolts or do i need to get longer ones to accomodate the add a leafs??
