Sponsored by: CARiD
after leveling Q
Old Dec 9, 2006 | 09:45 PM
BLUE ON BLACK's Avatar
Arrow after leveling Q
i leveled my truck 2" and love it but now i,m looking to lift the back end just a little. just so i can have a little tilt to my truck. any ideas would help
Old Dec 9, 2006 | 09:49 PM
djh1121's Avatar
2wd or 4wd?
You could do a add-a-leaf, taller blocks, or airbags. Just to name a few for you to think on.
Old Dec 9, 2006 | 09:51 PM
my truck is 4wd and i heard about leafs before and to be honest i don,t even know what there are. the taller blocks are they hard to install ?
Old Dec 9, 2006 | 10:18 PM
djh1121's Avatar
Add-A-Leaf or AAL is just 1 leaf spring you add to your current factory ones. It will give you about 1" - 2" lift. You have a 4wd so your blocks should be 2" right now. I'm not sure what size blocks are for sale in the aftermarket world but they are very simple to install. Both yield the same results. I think your best bet would be an AAL.
Old Dec 9, 2006 | 10:32 PM
hey sweet looking truck and thanks for the info but does an AAL afect the factory ride of the truck if not i think i might look into them do they cost alot ( also i,m going 33s next year will that afect anything with the AAL )
Old Dec 10, 2006 | 12:19 AM
FX4life's Avatar
Tire size wont affect your aal. You can go with taller blocks, ride rite airbags, or the aal, all will get the job done. the airbags will keep the level look, and help keep it level when towing. the aal will kick the rear end up and give it some rake again, but depending on the trailer it will also keep the truck level with a load.
here's a pic of mine with the 2.5" AS and 1.5" skyjacker aal
[IMG][/IMG]
Good Luck
Old Dec 10, 2006 | 09:05 AM
HiVoltage14.4's Avatar
Do they have a 1" AAL by any chance?
Old Dec 10, 2006 | 09:58 AM
ThumperMX113's Avatar
The AAL or airbags would be your best bet.
PS: I don't think they make a 1" AAL but I'm pretty sure they do make a 1-1/2" AAL.
Old Dec 10, 2006 | 02:38 PM
FX4life's Avatar
thumper is right, the only make a 1.5" and up
Old Dec 13, 2006 | 09:43 PM
BlueScrew150's Avatar
Is the mechanism of the AAL to stiffen the leafs, or is it raising the suspension?
ergo does the AAL stiffen the ride...
