Sponsored by: CARiD
towing with a leveling kit
Old Dec 12, 2006 | 03:51 PM
bassmaster1061's Avatar
will my truck look messed up pulling a boat every once in a while if my truck has a 2" leveling kit? thanks, mAC
Old Dec 12, 2006 | 04:01 PM
wandell's Avatar
If you think the rear is too low, just add a taller lift block. If the truck you are referring to is a 2001, you don't need a leveling kit. You can just crank up your torsion bars.
Old Dec 12, 2006 | 04:27 PM
newmandl's Avatar
Another option, depending on the weight of the boat/tongue is to buy a load leveling hitch of some sort.
Old Dec 12, 2006 | 05:05 PM
can you explain? it's a 4x2.
Old Dec 12, 2006 | 05:20 PM
2001 SCrew w/ 2" level + 285 75 16's + pulling a boat. Would the tires rub any?
Old Dec 13, 2006 | 06:13 PM
I haven't done these mods yet so i dont know how it looks. Would it stay level or not. would 285's rub?
Old Dec 13, 2006 | 08:54 PM
ChrisT's Avatar
I agree with adding the blocks in the rear after the leveling kit if you think it doesn't look level. That way you will keep the factory ride. The 4X2 won't have the torsion bars like a 4x4 would so the spacer up front will work for your set up.
Old Dec 13, 2006 | 09:44 PM
Paintboy's Avatar
yes
