rancho vs superlift vs rcd
Originally Posted by the goat
From Superlift installation manual 17x8" rim 5" backspacing preferred (5.25" max)
From Rancho's installation instruction Note "M" on page 2 "developed using following wheel: 18x9 wheel with 6" of wheel backspacing
Off course no experience with it yet since I’m still looking for lift kit. My truck is no monster. Right now your's is more monsturuse then mine
also; something intresting regarding wheels and tires specs check out this site http://www.wheelsforless.com/Ford/default.htm
I am speaking from experience... My stock 18's work fine on my lifted truck.
Just wondering; Which wheels/rims stick out more the stock one or the aftermarket ones.
The reason I’m asking if because I don't want my wheel and tires to stick out. If I could after I get a lift I would like to keep the flush look like stock with bigger tires (hope you understand what I’m saying; don’t know how else to explain it)
Originally Posted by BlueOval Breath
The aftermarket sticks out more due to 4.5" of Backspacing. The stock wheels have 5.5" of backspacing. I called 4wheelparts to ask about backspacing.. The example I was given kinda, sorta goes like this.." If you picture the lugnut side of your wheel and think about sliding that plate(where lugs and spokes meet in the center)in and out of the wheel, The futher in the lugnuts are the less backspacing and course the futher out provides more backspacing" Think of it like a deep dish wheel and a shallow dish wheel. If you run your stock wheels and a narrow tire you'll acheive the look you are after. I just think when you lift a truck it needs wider wheels and tires to make it look proportional... Just my .02 cents. BoB
I guess to get the tires not to stick out and get an accurate and constant reading you need to look at more then just the backspacing. Maybe offset of the tire and backspacing combined can give me a clue on how far if any the tires will stick out.
