Sponsored by: CARiD
How to adjust torsion bars?
Old May 18, 2006 | 01:08 AM
Chris J.'s Avatar
How do you adjust the torsion bars on a 98 f-150 4x4 reg. cab? Anyonw can help me let me know?
Old May 18, 2006 | 10:06 AM
dbdragracing's Avatar
I would also like to know....I guess it would be the same as doing it on my 2002 4x4 supercab? Thanks.
Old May 18, 2006 | 10:42 AM
Quackaddict's Avatar
It is very simple....suprised there isn't a tech article on it when I do mine I will post pics and see.
Basic concept is you jack the front of the truck up, pull of the wheels. If you look at the crossmember in the back where the torsion bars end you will see the "keys" that hold them. There is one on each side. You will see the bolts that screw up to the keys. Righty tighty leftly loosey....i.e. tighten them and it will raise the truck this is why it is referred to as cranking the bars.
Don't go just cranking away on them either. Mark where you started and go a couple of turns, put the wheels back on put truck on the ground and see how much you have gained.
Important Points:
1. The more you crank the rougher it is going to make the ride
2. Any lift over 1" gained will require an alignment
3. It may take more turns on one side to get it level
4. It will settle some once you drive it
5. It ain't rocket science takes about 3 tools and 30 minutes.
Old May 18, 2006 | 10:45 AM
If you look at the post "leveling kit/ tire question" in this forum Wandell has posted a pic of the bolts to tighten.
Old May 18, 2006 | 10:56 AM
ZAXJAX's Avatar
I did mine 6 months ago. Here's what I did.First, get the truck on a level surface and mark the each bolt pictured in Wadell's post. Second, measure the back of the truck from top of wheel well to bottom of rim. Make sure each side is the same in the back. Tighten up the bolt will raise the front end up. I did jack it up and it was fine. Don't raise it more than 1 - 1.5" inches. Do both sides and drive around to settle the torsion bars. Check your measurements again and repeat if necessary.
Old May 20, 2006 | 02:50 PM
Chris J.'s Avatar
Thank you both for all your help
Old May 22, 2006 | 11:49 AM
bigplayer6907's Avatar
its not nesseccary to jack the truck up but also any adjustment you do i would reccomend an alignment or it may cause uneven tread wear.
Old May 22, 2006 | 12:14 PM
bigtruck311's Avatar
here is a pic to help you out
Old May 22, 2006 | 07:56 PM
Dog'em's Avatar
I would like to find this out also, my 98 scab is starting to sag a little in the front and starting to rub on my 305's when I back out of the driveway. Just started having this problem, figured they need cranked up a little.
Old May 22, 2006 | 11:49 PM
did you even read the thread?? it tells you how. and if you dont understand what its talking about look at the picture bigtruck psoted then go look under your truck. its very simple. 2 bolts
Old May 23, 2006 | 08:06 AM
Dog'em's Avatar
Yes I did read the entire post so lighten up with the sarcasim. I'm just saying that I am in the same boat as ChrisJ and looking for the way to crank up the torsion bars a little. Seems there are different opinions of how and what to do.
1. Take tires off / Leave tires on.
2. Jack the truck up / Don't jack up the truck.
3. Always get it aligned afterwards / Only need alignment if lifted over 1".
Just asking before I start cranking away. Also anyone know how much approximate lift you get per one revolution turn of the bolt ?
Old May 23, 2006 | 08:10 AM
wandell's Avatar
I don't think it really matters whether or not you lift the truck off the ground or not. Also, I'd get an alignment (at least within 100 miles maybe) after you get to the height you want. I mean you never know, your alignment may already be out. Tires are too expensive to wear out.
Old May 23, 2006 | 08:43 AM
Funin damudd's Avatar
Here's what I did...
First off I took my little 2' level I had and came from the inside top of the fenderwell and measured to the floor all the way around the truck...(By the way my front end was out 1/4 of an inch to start with between the two front tires!!) anyway then I jacked up the truck on the drivers side just enough to get the weight off the tire then I cranked it up about 15 revs on the bolt and lowered it down. Then checked the height again. I did that again and again till I got both sides at the height I wanted. Witch by the way was right at an inch of lift.
I didn't check the alignment right away but put a 3" body lift on the truck and and new 33" tires then had it aligned 2 weeks later and the alignment was as I like to say, dead nuts.
Doc
Old May 23, 2006 | 09:34 PM
yeah the jack up was just a personal thing but doesn't hurt. Alignment is a good idea no matter how much lift but over 1" you really need one unless you don't care about your tires.
Old May 23, 2006 | 10:01 PM
Dog'em's Avatar
Thanks for the input fellas, got it taken care of tonight. Pretty straight forward, took longer to find an 18mm socket than to actually get it lifted and leveled. Does help to jack the truck up a little just to take some weight off, the bolts turn much easier that way. Went four turns and got 1 1/8" lift.
Thanks again.
