Time To Lift...
Originally Posted by FordF1Fitty
When I have the 6" suspension kit installed, is my truck going to be level or do I need to buy a leveling kit as well?
it is going to be levelled
procomp is 6 front 4 back.
Originally Posted by Johngs
All he wants is to stuff some big tires under there. He doesnt need the extra suspension travel of a suspension lift. Why spend several thousand dollars when a few hundred bucks can get him what he wants.
Ugh because it looks better!!! Also you can say I have a blah blah suspension lift. I have a Fabtech lift and spacer on my truck and I never off road. Dude get a suspension lift you will be so much happier. Originally I had the Daystar leveling kit up front. AT first i was like whoa I have to step up into my truck. Then that day will come when you pull up to a REAL lifted truck. Then you will want the 6inch kit. Save yourself some hastle and go with the 6inch lift. True testimony here
Well, it looks like I am going to go with the pro comp 6" suspension. Anyone reccomend a cheap tire and wheel package? I was thinking about just putting some 35's on the stock rims and ride it out til next spring and then go Bling, That should be ok right....?
Originally Posted by Silver05
I think only RCD allows you to roll with factory rims.
i know some one has already mentioned it but the gearing of your axles with the bigger tires is whats going to kill your motor/tranny not the lift.... if your going to 35's and your ring and pinion is 3.55 your going to dog the motor down. you will be disappointed in the pwr loss is basically what im getting at. save some extra doe and have lower ratio gears put in 4.56's or 4.88's.. you'll be happy..
