Suspension Question
Suspension Question
i lowered the front end of my Lightning like 5 months ago (springs/shocks) the wheels were a bit slanted... you know... i didnt think too much of it. anyway, my ball joints were getting bad and the alignment was off, so i had them replaced and the truck realigned. so the machanic who did this said i need a Camber Kit (i think thats how you spell it) so he put one in. i guess it was to make the wheels stright, right?!? well now the truck looks like its at stock height. is it just me being stupid or did the camber kit really mess with the right height?
thanx for any help
thanx for any help
thanx for any help
thanx for any help
SCotty
Camber
I have had many camber problems with my truck. My own doing, I dropt it 4/5. It was likely a set of larger concentric bolts in the upper A arms that they put on. The camber kit would not raise your truck back up. But it may appear to have done so due to the negative camber. If viewed from the front of the truck the outter part of the tire (the part you see from the side) will actually be "higher" than the innter part. When leveled out or when the excessive camber is taken out it will effectively "lower" the outter part making the gap from the tire to the wheel well as viewed from the side appear to be greater, giving the illusion that the lowering was undone.
