Sponsored by: CARiD
Steering Stabilizer?
Old Jan 26, 2006 | 05:29 PM
bigtruck311's Avatar
Originally Posted by wandell
Is your's a Pro COmp? I have a pic of a Rancho but it mounts differently.
no mine is fabtech
Old Jan 26, 2006 | 06:22 PM
freshjive959's Avatar
ill take a pic when im installing mine this weekend, but its a fabtech aswell
Old Jan 26, 2006 | 06:31 PM
Wookie's Avatar
I had a Procomp on my 03 ane it installed just like Bigtruck described. I posted a while back about installing the Procomp unit so I will try to find the old post and link you to it.
Joe
Old Jan 26, 2006 | 06:32 PM
Wookie's Avatar
Here is the old thread.
Steering stabilizer thread
This should help some.
Joe
Old Jan 26, 2006 | 07:04 PM
Bigtruck311, do you happen to have a closeup pic of you stabalizer? I just bought some Pro Comp shocks that came with a stabalizer and the instructions are pretty vague.
here is the best i could do with the skid plate still on i had to just stick the camara in and shoot so hopefully this can help
Old Jan 26, 2006 | 10:42 PM
yay! im not the only one with a dirty under carriage lol!
Old Jan 27, 2006 | 08:10 AM
wandell's Avatar
Thanks for the pic Wookie. I wonder why Pro Comp didn't use the same mounting method as Rancho and Fabtech.
Old Jan 28, 2006 | 02:52 PM
Wookie's Avatar
I would assume that they designed their mount to be used in conjunction with their lift kit. In that case the lower control arm bolts would already be removed so it would not be a big deal to use that as a mounting point. I did not want to go through the hassle of removing the bolt so I went looking for another location and came up with the hole in the crossmember. This location keeps nearly the same geometery as the original location but is much easier to install. The only thing is that the hole is slotted so there is a chance that the bracket could slip. To mitigate this I used a lock washer on either side of the bolt and tightened the crap out of the nut. When I removed the stabilizer before I traded that truck in the bracket had not moved.
Joe
Old Jan 28, 2006 | 07:00 PM
so i did mine, but i had to go to my dads work since i dont have a torque wrench( im only 19) so i forgot the camera lol, neways it wasnt hard at all to install. and so far so good with the ride vibration
