Sponsored by: CARiD
steering wheel vibration
Old Feb 12, 2005 | 05:58 PM
slowrancher's Avatar
my truck is a 02 supercrew fx4.it is very tight,but i seem to feel all bumps and vibrations threw the steering wheel.has anyone had this trouble?
Old Feb 12, 2005 | 08:35 PM
snappylips's Avatar
I don't have an FX4, but I definitely feel a lot more through the wheel when I have the air pressure up around 35 PSI as compared to 28-30 PSI. You say it's tight, but get a second opinion. Get it up on a lift and have it checked out, especially the pitman and idler arms.
SL
Old Feb 13, 2005 | 11:30 AM
how would i find out exactly how much air to run in a set of 285-70-17bfg-at-ko's
Old Feb 13, 2005 | 11:38 AM
Johngs's Avatar
Most of the BFGs like to run around 35-45 PSI depending on how you use the truck, but it can also depend on what size rim you are running them on.
Old Feb 13, 2005 | 01:36 PM
i just checked and the driverside had 39,so i let it to just under 35 on all and it helped alot
Old Feb 14, 2005 | 03:54 AM
snappylips's Avatar
Glad it helped. What part of the country are you in?
SL
Old Feb 14, 2005 | 03:23 PM
ga
