Sponsored by: CARiD
Question for those with cranked bars
Old Sep 17, 2004 | 09:41 AM
zski128's Avatar
OK, so I want to crank my torsion bars to get 1 - 1.5 inches of lift up front. I will alos be purchasing new shocks to replace my stock ones. I called Rancho to ask what they recommend for front shocks with a 1-2" lift. They say the stock replacements they have will over extend and should not be used and the ones for the 4" lift are too long. I would really like to get Rancho RS9000Xs. What do you guys use up front when you crank up your bars?
Thanks for the help,
Rich
Old Sep 17, 2004 | 03:52 PM
wandell's Avatar
You need a replacement shock for a stock truck. If you crank up or decrease the preload on the torsion bars, you still have the same amount of travel.
Old Sep 19, 2004 | 04:48 AM
ArcticOval's Avatar
Because of limitations of traveling between the upper and lower limts of travel (bumpstops or snubbers) replacement of shocks after doing a torsion bar lift is not necessary.
