Sponsored by: CARiD
Lift Pictures
Old Aug 4, 2000 | 01:32 PM
TexasAg's Avatar
Post
RedBullSr-
Whoop '97!
TxAg
Old May 16, 2001 | 09:34 PM
offroad guy's Avatar
Cool
TexasAg- got any pics of your truck? Thanks.
1997 F-150 XLT 4x2 SC 4.6L
Flowmaster 40 Series Delta Flow with 3.5"x22" Chrome Slach Cut Tips
Wish List:
-3" Body Lift +
-3.5" Fabtech Spindle
-35" BFG MT Tires
-American Racing Atlas 16x8 Wheels
Old May 18, 2001 | 04:38 PM
crazedf1's Avatar
Post
roberto
looks good. do you have any tips for the install? im going to put almost the same setup on my truck.
2000 4.2l V-6 w/sport package std. cab. 2wd, bright red
billet grille
clear corners
herculiner bed liner
k&n filter
sony head unit
two 10" kicker comps.
sony amp
viper alarm
future: (being in college cuts most of the funds)
spindle lift
fipk
chip
headers
exhaust
Old May 18, 2001 | 06:15 PM
Roberto's Avatar
Post
Yeah. Paint your spindles before the install, they rust out very quick and look awful. Get new grease seals for the spindles.
Also install the spindles first, if your truck has a lot of rake, you may not need the blocks in the rear.
Roberto
Old May 18, 2001 | 07:55 PM
Helloe's Avatar
Post
Hey Roberto,
Sharp looking Rig! Where did you get those spindles from if I may ask?
And do they come as a kit or is this sort of a home made lift set-up. I haven't seen to many choices for my 2001 in the lift dept. so your set up is looking good. The pictures are great to. I hope I can bug you a little in the future for some more info about that set-up.
Thanks for sharing
2001 5.4 S Cab Lariat
ORP / 3.55 L/S
Class 3 Tow Package
Gibson SweptSide
K&N Gen 2 FIPK
Superchip FLIP CHIP ( on order )
Next Mod - Sound System ?
Old May 19, 2001 | 02:49 PM
Roberto's Avatar
Post
Helloe:
You are looking at very old pictures. I bought my spindles exactly one year ago, at 4 wheel parts in Austin. At the time, Procomp was the only company making spindles for the F150 and they were expensive, I paid I think 575.00 for the spindles and paid separate for the shocks and the rear blocks. Since then, several companies started making the spindles (Procomp, Fabtech, Rancho, AIM) and they are a lot cheaper.
visit www.4wheelparts.com to get an idea of the prices. Also, take into account that a good lift consists of three parts:
1. The lift
2. The bigger tires and rims
3. Ring and Pinion set.
When you make your budget for the lift, make sure to include all three things.
When I went from 255-70-16 OEM tires to 285-75-16's I couldn't believe how bad my mileage got and the very noticeable lack of power. So I got a superchip and though it makes huge difference in performance, the engine still was not operating in the right powerband (besides the speedometer being off)
still using a lot of gas until I decided to change the rear end gears. I went from 3.55 to 4.10 and I am very satisfied with it.
The speedo is back to normal, and 70 MPH equals 2000 RPM, running very sweet.
My last tank of gas was 20 gal at 370 miles in the odometer, which is about 18.5 MPG. Before the gear change 20 GAL lasted 280 miles. Big difference. Tomorrow (May 20) makes exactly one year with my lift and absolutely no problems. Another item that I added recently is a steering stabilizer and it makes a huge difference from before. I tried to get a dual setup (look for DAVENSA's pics on his setup) But nobody locally wanted to make it. I intend to make it myself, I picked up a used, small welding machine for the purpose.
Sorry for the long post. I hope it helps.
Roberto
Old May 19, 2001 | 03:41 PM
guardburke's Avatar
Post
Are gears hard to change? I would like to swap my gears for a 4.10.
1998 F150 STX 4.6L
Aim 3" Coil/A-arm Lift. Rear blocks
Ranch Rs9000's
Pro Comp 33x12R17 AT
K+N filter charger
Clarion CD Player
White Face Gauges
Leather "Harley" seats
Flo Pro Exhaust
Clear Corner Lights
Tinted Windows
Old May 19, 2001 | 06:17 PM
Roberto's Avatar
Post
Yes. You need access to a hydraulic press because the pinion gear bearing is press fit. You also need gages to measure the backlash and a micrometer for the shims and a torque wrench for the bolts. If you are not mechanically inclined or trained, it is best to have a shop do it.
I did mine, because the local shops didn't want to do it, but if I had to do it all over again, I would find a shop in Austin and I would rather pay 400.00 (parts and labor) than do it myself.
Roberto
