To kenster (pop sound or thunk sound.)
I had the the same problem with my ford.I found that it was coming from the rearend and driveline. my cracking sounded each time i made a right turn into or backing out of a drive way or a sharp turn it made a cracking sound or thunk sound. Found i had to re-align the rearend with the driveline.My rearend was pointing a little downwards out of alignment with the driveline loosen the all U-bolts and rocked the truck backward i believe by moving the rear tire. I use a degree meter on the rearend which you can buy for a couple of bucks intill it was the same degree as the driveline retighten all U-bolts. After that it made little thunk bearly hear it. I then replaced both universal joint and that eliminated the problem all together.
I hope this helps with your problem sound very simular to my problem good luck
[This message has been edited by hmiz (edited 01-09-2001).]
