4X4 Chasis Lubrication
Check on top of the idler arm. Thats were my second one is. It is kind of tough to get to but...
Grease away
'97 F150 Lariat, Flareside, white/sliver, SC, ORP, 5.4 (FQR 8/99) running Mobil 1
Mods: 305/70/16 GY ATS, AR Baja wheels, dual exhaust, Smittybilt Nerf Bars, Edelbrock IAS Shocks, K&N Filter, Carbon Fiber Bug Gaurd and rigged the fog lights too.
Grease away
KKIRT1 is correct. If you look at the idler arm you will find one at each end. The one toward the engine is on top. I used a grease gun with a flex hose to get at that one. Now doesn't it make you feel bad when a shop tells you oil & filter for $15.95 and a grease job for $4.95 (for two fittings).
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, 4.6, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
