Rear Sway bar!!!!!!
Rear Sway bar!!!!!!
Just got back from installing the rear sway bar with a friend of mine. Was a bit tricky figuring out how to mount it, but we got it done. I still need shorter end links, but will work as it is now for the time being. However, I can deffinatly hear it when I stop or much articulation occurs. Will some WD-40 being sprayed in the D bushings help any? or will I need to put some of the polyerethane grease in them like I did on the front? I'll get pics in the next few days.
Re: Rear Sway Bar Install
Originally posted by Francis
I have the Hellwig rear sway bar kit. The bar goes over the differential housing and I can not get it installed even raising the vehicle 6" off the ground.
Is it me or is a lift required?
The Hellwig front sway bar install was no problem...
1) Place a floor jack under the receiver hitch and jack the truck up as much as you can.
2) Start from in front of the rear axle. Angle the bar sideways, and working from the drivers side of the driveshaft, slowly work the passenger endlink connection over the driveshaft until you work the swaybar around and onto the top of the pinion. It takes a little finagling but it will go. Make sure to take care not to damage the pinion sensor lead (top/front on the pumpkin).
3) When you get the swaybar in place over the pinion, lower the floor jack and complete the installation per the Hellwig instructions.
Hope this information helps.
Just for you Big Deal.
and below are some of the pics. Its not wut I was totally wanting, but some work it will be ideal. I'm going to have it powder coated blue for $30 then get some adjustable end links from So-Cal speed shop. But the handling is so much better. I'll get some better pics when its all cleaned up.
GOD I LOVE THAT PICTURE!!!!!!!!
By the way how did you put a picture of your truck on her great body? Is there anyway you can send me that pic I have not been able to find it anywhere.
Richard D.
WHILE YOUR HERE CHECK OUT MY GALLERY:
https://www.f150online.com/galleries....cfm?gnum=2479
Richard D.
ok, I cant get your email off this site, so give me an email
phillipsvt@hotmail.com and I will send you the pic then.
Hey SVT I have photoshop 6.0 and have been trying to figure out how to cut and paste my pictures into others like you have doen with the Ally photo if it is asking to much could you e-mail me maybe the steps I need to take to get it done If you have some time .
Thanks,
Richard D.
F1504RAD@aol.com
Thanks,
Richard D.
F1504RAD@aol.com
Re: Big Deal! THANKS!
Thanks for your information!
I'll try it, again, this weekend ...
How high did you lift the receiver?
2x4 or 4x4 shim on the floor jack?
Regards,
Regards,
