SuperCrew
Seat Belt Recall... opinions?
Old Jun 3, 2002 | 07:08 PM
Crewd's Avatar
Question Seat Belt Recall... opinions?
Hi Gang,
Ford has repeatedly sent me notices about the seat belt buckle retention recall, even though one of their mailing showed me how to check for the problem myself. I checked my truck but didn't find anything wrong with the buckle. Has anyone had this problem corrected by the dealer? I'd hate to miss work one day for a problem that may not even exist.
My SCrew was built in February 2001.
Thanks,
Jon
Old Jun 4, 2002 | 12:16 AM
Wino's Avatar
i'm not sure what the letter says that ford sent you. but i know the tester fails alot of buckles that. me just putting the buckle in by hand latches ok every time. its up to you. a day off for this does bit. but if the buckle fail's, that would be worse. good luck.
Old Jun 4, 2002 | 07:53 AM
redkona's Avatar
My seat belt had this problem. I figured that a day of work was worth a lot less then a life in the hospital if I should get hit or hit some one!!!
Old Jun 4, 2002 | 08:20 AM
Robdude30's Avatar
I had mine checked last time I got the oil changed. It only takes them a minute to check. Mine did not have the problem so I was in and out quick.
Old Jun 4, 2002 | 08:57 AM
Rockpick's Avatar
Moderator &
Crewd,
Just my opinion but, it certainly wouldn't hurt anything to swing by at lunch or something of that nature and have them check it out. Just call ahead and talk to the service manager and let him/her know of your time constraints.
If it's an issue, take the necessary steps to make sure it's fixed. I'd rather take a day of vacation than two weeks in the hospital because I ate the windshield. Also, lots of time, the dealership can do routine and small repairs on the weekends. I'm not sure if this would help your cause but, it's certainly worth looking into.
If it's not an issue. You're no worse off than you were before and you'll have the piece of mind knowing that you'll be restrained if needed.
RP
Old Jun 4, 2002 | 09:38 AM
ts_toy's Avatar
Here is a thread I started about the seatbelt recall. I hope this helps.
https://www.f150online.com/forums/sh...threadid=66785
We actually had this fixed a few months ago, but just got the recall notice just 2 weeks ago.
2001 Screw 4X4 XLT
4.6L
Skids
Bright Red
6-disk CD Changer
Sliding Rear Window
9" ac/dc TV/VCR for trips
Westin Nerf Bars
Lund Bug Shield
Spray in Liner
Snugtop XTR Topper
Ordered 6 Dec 00
Born 8 Jan 2001
Got from Dealer 22 Jan 2001
Old Jun 4, 2002 | 11:20 AM
LakeSands's Avatar
By following the instructions in the letter I could cause on of mine to fail. The other was ok. I sure would not take a chance. It only took them a few minutes to do the swap.
Old Jun 5, 2002 | 12:47 PM
fritoz's Avatar
I'd guess someone in the legal dept. said, "Uhh, anyone remember Firestone..???", and they decided to recall 'em ASAFP!
Old Jun 5, 2002 | 09:37 PM
SDScrew's Avatar
Would someone mind posting the instructions from the letter ford sent? I bought mine used and don't get letters from ford.
Thanks,
Old Jun 6, 2002 | 10:44 PM
Home skillet's Avatar
Thanks,
Ford tracks vehicle ownership by the VIN #. So if there are any recalls, you should get a notice. Any Ford dealer can verify any recalls you may have.
