About this wire harness.....?
Got the truck today and everyone who has seen it loves it, including me!
Anyway in front of the right front wheel is a wiring harness-it is split such that one side goes to the horn and one to the fog light. However, on the left side in front of the left front wheel is apparently the same harness- but at the split one side goes to the fog light but the other is just hanging. Since there is no horn on the left side that I can see is it just supposed to be tied off or what?
Any help is appreciated.
Screwdriver,
That were a resistor goes for day time running lights. Jim
Came from the factory:
2001 F-150 SUPERCREW LARIAT 2-WD
Chestnut Over Harvest Gold
5.4 V/8
Leather Captain's Chairs
Moon Roof
Bed Extender
AM/FM Cassette And 6-Disk CD Charger
3.55 Limited Slip Axle
Class III Trailer Group
Installed by Tipton Ford:
Billet Grill
******* Fiberglass Bed Cover
Bed Rug
Expedition Bumper With Fog Lights
Hood Shield
Door Vent Shield
4 ft Round Bed Rails On Top Of Bed Cover
CB Antennas Mounts On Top Of Bed Cover
Ford Running Boards
Engine Hour Meter
Wood Dash Trim Kit
Tint Front Door Glasses
Continuance Operation Solenoid Switch To Work Off The Ignition Switch To Put Power To CB & Amp
2" Rear Lowering Shackles
Air Lift Spring Helper For Rear With In-Cab Controller
F-150 Harley Davidson Edition Exhaust System
Effex Lighting Kit For Running Boards To Operate With Inside Lights And Remote
K-40 3ft CB Antennas
Cobra 25 WXNWST CB Radio
Palomar 225 Amp
Husky Floor Mats
Daytime Running Lights
Lighted Tail Gate
5.4 V/8
Moon Roof
Bed Extender
Billet Grill
Bed Rug
Hood Shield
Door Vent Shield
Ford Running Boards
Engine Hour Meter
Wood Dash Trim Kit
Palomar 225 Amp
Husky Floor Mats
Lighted Tail Gate
Screwdriver,
Forgot to give you the address for my truck.
http://www.***-internet.com/jimwalker/newpickup.htm
[This message has been edited by jimusnsfa (edited 11-20-2000).]
Screwdriver,
Yes you can tie it off. Their should be a plug in the end of the wire. Thier is one of
the two wires is hot when you have the key on, but when the head lights are on it is not hot. The Resistor that is plug in to the wire drops the volts to 10 volts on the low beam head lights so they dont burn out and
the lights aren't to bright for day time
running lights.
running lights.
Did anyone ever find out the part numbers for the DRL Resistor and the DRL Relay Block?
Order Code Item Description Dealer Invoice Suggested Retail Price
F150 SUPERCREW CAB 2WD 139" W.B. $24,656.00 $27,860.00
Destination Charge $715.00 $715.00
99L V8, EFI (5.4 Liter) $680.00 $800.00
44U Automatic, 4-Speed w/Overdrive STD STD
508A Series Code • Lariat N/C N/C
18E Cab Steps $213.00 $250.00
535 Trailer Towing Pkg., Class III • Includes 7-wire Trailer harness, class III hitch receiver, H.D. Shock Absorbers & H.D. Electrical/Cooling Pkg. $298.00 $350.00
43M Moon Roof, Power Glass includes Mini Overhead Console $688.00 $810.00
90P Seat Adjuster, Power Driver's Includes Auto Headlamp Control STD STD
90H Seats, Heated • Lariat $207.00 $245.00
XH9 Axle, 3.55 Ratio Limited Slip Rear $243.00 $285.00
63E Bed Extender, Stainless Steel Cage $166.00 $195.00
153 Bracket, Front License Plate (LPO) N/C N/C
60C Entry System, Illuminated Keyless Remote Control STD STD
41H Heater, Engine Block (LPO) • Models w/Trailer Towing Pkg. 535 $30.00 $35.00
954 Paint, Lower Two-Tone Includes Body Side Stripes. $192.00 $225.00
91P Radio, Premium AM/FM Stereo w/Cassette Includes 6-Disc Compact Disc Changer $251.00 $295.00
EH Seat, Leather Surfaced Split Bench • Lariat (Medium Parchment) N/C N/C
T5S (5) P275/60R17 OWL • Lariat STD STD
433 Window, Sliding Rear $107.00 $125.00
AQ/LL Beige, Arizona Metallic/Blue, Deep Wedgewood Metallic N/C N/C
$28,446.00 $32,190.00
Dealer Profit() $500.00
$28,946.00
Order Placed 11/3/2000
Serialized on 11/9/2000
Estimated Build Date Week of 11/27/00
Produced 11/28/2000
Estimated Delivery to Dealer 12/18/2000
$28,946.00
Produced 11/28/2000
dbdunn,
Here is the part no.
XL3Z-14A601-AA DRL Resistor
YL1Z-138218-AA DRL Relay Block
Hope this helps you.
