SuperCrew
Water in tail lights
Old Nov 10, 2000 | 07:43 PM
mjhind's Avatar
Thumbs down Water in tail lights
With all the rain we have had lately I have gotten water into both tail lights. Anyone else have this happen to them? The dealer is going to replace them and do a few other fixes for me. I had read about mud getting into the tail lights, but not water.
2001 Supercrew XLT 4x4, 5.4, tow pkg, limited slip, skid plates, 6 disk, keyless entry. Deepwedgewood blue ext. Dark graphite int.
Mods: full tint, westin chrome nerf bars, AR chrome sliders 16x8 and BFG AT 285/75
Old Nov 10, 2000 | 08:56 PM
Thad's Avatar
Post
I posted a few questions on this in May or June. What I did was to put on a molded mud flap . I also bought some ribbed rubber used for flooring in R.V.'s and added it to the width of the inner wheel well. I used plastic push in plugs to attach it to the wheel well liner and unless you look closely, you wouldn't know it didn't belong. Sounds complicated but wasn't and did solve the problem.
Old Nov 10, 2000 | 10:50 PM
woody24's Avatar
Post
So, is the mud getting in from under the fender well? Or is it getting in from the outside part of the fender?
Old Nov 11, 2000 | 10:50 AM
Thad's Avatar
Post
The mud and water get in from the wheel throwing it back and it falls down through the large holes above the light. Unbolt the two bolts you can see when you lower the tailgate, take out the light slightly and look at the opening above the light in the housing. I wonder if the composite bed needs more cooling around the light?
Old Nov 11, 2000 | 03:24 PM
mjhind's Avatar
Cool
I've gone mudding a few times with no problems. The lights are clean, only water into them so far.
Old Nov 11, 2000 | 07:45 PM
OKCrew's Avatar
Post
I read about this problem quite awhile ago and thought of a precautionary fix (which I have yet to do).
I think I'll get some elastomeric roofing ice dam material and cut some patches to paste over the holes. The patches would have slits to slip around the wire harness. They would also be readily removable if needed.
OKCrew
(See ya'll at Southern Hills for the 2001 U.S. Open)
2001 SuperCrew, Lariat 4.6L 4x2 , Deep Wedgewood Blue/Harvest Gold, 3.55 Limited Slip, Bench Seats, 6 Disc CD Changer, Ford Bed Liner, Bed Extender, Class III Tow Group, Ford Platform Steps, Ford Bug Shield.
Mods: Astro-Cap EuroLid (Fiberglass Hard Tonneau), Husky Liners, Clarion Camouflage PSWFF15T Powered Subwoofer and 4 SRC5753 Component Plate Speakers.
