SuperCrew
Power Lock Wiring
Old Nov 11, 2000 | 04:48 PM
RI SuperCrew's Avatar
Post Power Lock Wiring
I need to determine what type power locks the SCrew XLT has.
I do NOT have Factory keyless entry.
The switch has 7 wires.
Pink/Yellow 12v @ unlock -- Ground @ rest
Pink/Yellow 12v @ lock -- Ground @ rest
I believe it is 5 Wire Reverse polarity.
If so, can I find/use these two wires in the kick panel with a reverse polarity module/relay harness. Or do I need
to make the connections @ the door lock switch.
Also can you recommend a Pats bypass to use?
Any tips on a remote start/alarm install would be greatly appreciated
Old Nov 11, 2000 | 07:03 PM
OnBelay's Avatar
Cool
It is a 5 wire system, kickpanels.
DEI module, about $30
My credentials? Yeah, they're right over there....
framed and hanging on the shade tree.
Old Nov 11, 2000 | 09:32 PM
ralderman's Avatar
Post
RI,
You do have the 5 wire system. You need 2 5 pole relays, and will have to use the pink/green wire for unlock, and the pink/yellow for lock. If you find the wires that come from the driver door you can find those 2 wires in the bundle. Wire your two relays together by attaching relay one #86 and #87 to relay two #86 and #87, put a 10 amp inline fuse in, and attach to 12v. Relay one # 86 will be attached to your control box, and relay two # 85 will be connected to you control box. Now on each relay you have 87a, and 30 left. One will be unlock, and the other relay lock. This is determined by the connection from the system to each relay. Cut your ping/green wire switch side to 87a, and the motor side to 30. Do the same for pink/yellow.
2001 Super Crew XLT 4x4,Toredo Red/Harvest Gold, Tan Interior, 4.6l, Keyless Entry,Towing Package,Captain Chairs, Line-X Bed liner, Limited Slip,3.55 axle,Skids,and Sliding Rear Window
