Lowered Screws
I can't wait to go to the formula 1 race in november! Tickets are over a 1000 for the grandstand...so I may not be in the grandstand lol...depends on what my wife says..
Have those camber kits in just before the alignment or the will charge you about 50.00 plus labour to install. I don't have any shims in for my rearend. I have lowering leaf springs and shackles that angled the spring so I didn't need them. Your truck look bad ***. Nice work.
I was trying to calculate my pinion angle and whether I needed the shims last weekend, after some research and driving the truck around I'm almost convinced I don't need them. Don't have any vibration, but I have heard if the pinion angle is wrong the u-joints could suffer.
The angle of the tranny and pinion should be close to the same degree of angle.(meaning Paralell to each other) If not your tailhousing bushing and seal or u-joints could suffer. If I remember right my tranny was just below 2 degrees down but because I was so low and I have a custom 2 piece driveline I had to raise the tranny up 5/8 inch and raise the center support bearing.
You have less than 2 degrees difference. You should be pretty close. Maybe a 1/4 inch shim under the tranny mount. You want at least a degree for the u-joint so the bearings will spin. What was the driveline degree?
I took some more measurements, but not on level ground as I did the first time. Trans; -5 degrees, driveline; -2.5 degrees, and diff; -4.5 degrees. Instead of shimming the trans will a pinion shim get it where I needs to be?
1999 Lightning Rims
