Lowered Screws
Went pretty good, ran into a couple problems here and there. Nothing like lowering a Integra
but it went good and like the way it came out.
Camber kits don't take away the negative camber, they only make alignment adjustments easier. I had to slot out the frame where the A arms mount a bit more to get the alignment correct. And that was with just a 2" coil front drop.
Eibach has a -2/+2 Camber kit.
I don't if its the same, but the camber bolt kit should fix the problem. I don't think ever one out there that lowered there F150 has to mod there frame to fix there alignment. Not trying to be a a$$, just saying.
Have those camber kits in just before the alignment or the will charge you about 50.00 plus labour to install. I don't have any shims in for my rearend. I have lowering leaf springs and shackles that angled the spring so I didn't need them. Your truck look bad ***. Nice work.
Heres One of mine a lil old but I love this pics
