Getting a rearend UPGRADE!
Ok, I'm over the fact that I sunk the rear end and messed up the diff. So Its getting rebuilt next week with new gears,bearings and a superior LSD..... a Eaton Detroit TrueTrac.
The new LSD is going to be HUGE improvement over our weak stock LSD's.
http://www.eaton.com/EatonCom/Produc...trac/index.htm
Can't wait!
Can't wait!
I hear ya... nothing wrong with a little extra TRACTION!!!!
I have detroit lockers front and read on my 89 Bronco mud truck and puttin the power to the tires is crutial.
SouthernStyle
SouthernStyle
Do you need LSD axles to be able to install Tru-Trac? I have a 3.31 ratio non-LS axle and want to get Tru-Trac, but I'm unsure if it'd be compatible with my current set-up.
Ok, its finally done!
New bearings all around, new axle seals, and a spakin new Truetrac. We reused the old gears as they werent worn wrong, the noise came from the bearings.
Its drives so smooth and the traction lock i get is amazing!
