SuperCrew
Computer Code...where else can i find it
Old Oct 8, 2007 | 03:46 PM
cdiddy4224's Avatar
I know its supposed to be on the passenger side door jam area, but mine is gone. I tried looking under the dash on the passenger side near the firewall and nothing Where else can i find the computer code? This is driving me crazy
I have an 02 btw
Old Oct 8, 2007 | 06:11 PM
I12AV82's Avatar
I have an 02 btw
If you're referring to the plug for computer diagnostic equipment, I believe it was on the driver's side under the dash, somewhat above the gas pedal on my 1999. I suppose they could have moved it, however.
Old Oct 14, 2007 | 04:19 PM
twiggy103's Avatar
I have an 02 btw
Look under the dash, against the door panel, near the fire wall on the passenger side. You may have to take the plastic arm off of the computer to read the computer code. I had the same problem finding mine until I removed the "arm or bracket". It was covering the number.
Old Oct 21, 2007 | 05:55 PM
jman_529's Avatar
computer code plug
Just installed a Scangague II on my 02 Supercrew. Computer code plug is located on underside of dash, right side of steering column next to the trailer brake connection. As memory serves it is directly in line with the gas pedal.
Hope this helps.
