SuperCrew
4x4 and the rain?
Old May 7, 2007 | 08:03 PM
dfd896's Avatar
Question 4x4 and the rain?
Whats is the general opinion on running 4wd in the rain do or dont? and for how long?
TB
Old May 7, 2007 | 08:50 PM
skip nay's Avatar
I would not unless you plan on running it very hard constantly and spinning tires.
Old May 7, 2007 | 09:54 PM
bridge's Avatar
The owners manual says that it's bad to engage the 4WD on pavement. It's only for off road and loose gravel conditions. Not having a whole lot of transmission knowledge myself, can anybody chime in on why this is?
Old May 7, 2007 | 10:06 PM
I12AV82's Avatar
I'm not sure, but I've read that before in the owner's manual.
It must be something with the design, as a GMC I had for a little while had an "Auto" 4WD feature that would kick into 4Hi whenever there was wheel slip or you would be turning at high speeds, to add control I suppose.
Old May 7, 2007 | 10:22 PM
Gear Jammer's Avatar
The tires have a good grip on the pavement and it puts a bind on the driveline,especially while turning.
Old May 8, 2007 | 10:33 AM
APT's Avatar
APT
There is no differential for the front axle, so when you turn the gears bind if there is a lot of grip. Rain is questionable. Snow on pavement, gravel, no problem. Rain, I wouldn't do it. These trucks don't have AWD or automatic 4wd except the latest Harley Davidsons.
Old May 8, 2007 | 06:37 PM
MrSquirrel's Avatar
i use it in extreme rain conditions, but never take sharp turns with it on, and i never go over 60 with it engaged, you can tell a difference, with 2wd in the rain(heavy) you stomp on the gas and your going to spin, but with 4wd none of that, but if you were to use it, i would only in very harsh rain conditions
i have never had a problem with it
Old May 9, 2007 | 11:32 AM
roloplex's Avatar
Wow I have never heard of using 4 wheel drive in the rain. I thought 4x4 was for deep snow and off-roading. Maybe thats why you never see rear wheel drive cars out in the rain.
Old May 9, 2007 | 02:54 PM
()smoke()'s Avatar
i never use it on pavement unless said pavement is covered in ice or deep snow to the point that i need more traction
Old May 10, 2007 | 01:12 AM
Cougar Guy's Avatar
I honesty can't see ever needing to put your truck in 4WD for rain, unless maybe you are on a dirt road that has turned slick with mud . . .
Old May 10, 2007 | 01:44 AM
I never engage my 4wd ever... I cant seem to find the button for it
-Patrick
Old May 10, 2007 | 09:46 AM
APT's Avatar
APT
I had a 4x4 Dakota with open rear diff that I did engage 4wd when I wanted to accelerate quickly in the rain. But it was a lease and I didn't turn with 4wd engaged. I could see the need for 4wd w/ open diff, but not w/ LSD that my F-150 has. I still wouldn't do it on a truck I plan to keep long term.
Old May 10, 2007 | 01:05 PM
LRG's Avatar
LRG
I'd avoid it unless it's REALLY slippery out there. I screwed up the front drivetrain of an Explorer I used to have by turning with 4X4 engaged and having too much traction for it to slip. Personally I don't think I'd ever use 4X4 in the rain.
