SuperCrew
New uses
Old Mar 8, 2004 | 07:58 PM
03Screw's Avatar
New uses
Does any one have other uses for the second door on the overhead console? I dont have a garage door opener (not that this rig will fit in my garage anyway) I keep looking at it and wondering what else I could use it for. Its an 03 screw by the way
Old Mar 10, 2004 | 01:18 PM
rogone's Avatar
I have seen some posts that show this area, or the door in front of it, being used to hold an XM or Sirius display module. You might do a search of the threads and see what you come up with if this is something you'd be interested in doing.
Old Mar 10, 2004 | 01:27 PM
LightningCrew's Avatar
Yep, I had a sunroof installed in mine!!
Old Mar 11, 2004 | 06:47 AM
BostonCowboy's Avatar
Registered User
I put all my switches. Front hidden KC's, Backup Lights, Hidden Strobes and Wig Wags.
Old Mar 11, 2004 | 06:54 AM
petersde's Avatar
Outstanding idea! How did you run your wires?
Old Mar 11, 2004 | 08:19 AM
Registered User
I took the console out. I ran one hot and one ground to the first switch and jumped these to the other three switches. Then I ran a four conduit wire to each switch.
All of these were tucked in the headliner and run down the pillar and ended up behind the drivers kick panel. From there, I tied in each device. Behind the brake pedal, there is a rubber grommet that I poked a hole in to run the hot and ground to the engine area.
I think there was another guy on this board that ran everything to a circuit panel behind the rear seat of his extended cab. He everything there fuses, relays.
