What headers on 5.4 3v with whipple
Looking at the stainless works 1 3/4 headers and some other knock offs on eBay of same size or the standerd 1 5/8 headers looking for the biggest gains in power and torque truck is used to tow heavy loads but is only towing on 6 psi which is the 8 pound pulley I've got a 10 lb pulley once we finish the fine tuning
So just trying to what is best
Robert
Robert
Kooks doesn't have headers for us. 1 5/8 is the better, but less common, size from what I've heard; 1 3/4 is just a touch too big apparently. Stainless Works aren't much cheaper than Dynatech. American Racing is another option, though I'd just go Stainless Works if you're okay with how much they cost. I have OBX ones with Percy's Vibelock locking header bolts and new OEM gaskets and I still think mine are leaking, even after taking those expensive measures against leaks. But I'd do them again over paying more than double for a different set.
I wouldn't worry THAT much about the size of the primaries. The 1 3/4 have to be better for your truck than for mine because of the blower, even if 1 5/8 might be slightly better.
The Stainless is the "best" kit IMO with all things considered. And it comes with a y pipe, IIRC, that can mate up to a catback without too much fuss. My OBX kit's Y pipe mated right up to my Roush SIDO catback using one piece of the factory exhaust. I'd do a full custom exhaust though with 2.5" duals and an x. OBX has 2.5" collectors and 2.5" y pipe that combine into a single 2.5" pipe to mate to the 2.5" factory exhaust. I was unwilling to throw away my $600 catback, so I kept it. Otherwise I'd be running true 2.5" duals with an h or x pipe crossover with 2 Borla mufflers. That will happen at some point, if not running 3" pipe from the y into the 3" pipe before the SIDO muffler.
Why 3" collectors, Crash? You usually want to run 2.5" dual pipe all the way back (or combine them into a single 3") to maintain low end, no?
The possible leak is a massive annoyance to me, but the 16 (or so) gauge stainless steel does project much more engine noise than thicker normal steel, so mine may or may not be leaking. I've had the "exhaust guy" at the dealership I work for tell me the same thing after listening to mine. I've gotten over it, but it's still annoying as hell not knowing for sure one way or the other.
Can you hear ticking when in a parking garage or going up on ramps, etc? I can just hear a lot more engine noise than before. I am really **** with this kind of thing though . . .
