thinking of a big change...
Old May 28, 2013 | 04:25 PM
  #31
kens fx4's Avatar
Originally Posted by IR0NS1N
What's the meth mixture? I wonder if you have to much water not enough meth hurting power. I would try dyno runs on and off meth (obviously different tunes with each)
Also why are you running off the MAF instead of boost? Is your controller progressive injection? I had a devils own kit on a cobalt ss and it would start injecting at 7psi and go full squirt at 12psi until max 17psi. Reason I ask is if its dumping 100% at lower rpms it will cause the engine to bog.
mixture is right (direct from snow performance)
using the MAF cause that's what they (snow performance) suggest for a whipple supercharger on a f-150
and it is progressive.. comes on around 4000rpm..
Old May 28, 2013 | 06:29 PM
  #32
IR0NS1N's Avatar
I think you need to get the truck dynoed, a non meth tune and a meth tune I'd be interested to see what happens when the meth kicks in. I wonder if it actually cools the IAT down so much (depending on where your sensor is) that the truck pulls timing thinking its to cold? I know mine doesnt advance until IAT is over 100.
Old May 28, 2013 | 09:05 PM
  #33
kens fx4's Avatar
need to find a good dyno shop close..
Old May 30, 2013 | 04:43 PM
  #34
kens fx4's Avatar
update...
still waiting for VMP
tried to launch in 2wd..
NEVER going to happen with out sticky tires
either I got a terrible 60' or they just went up in smoke..
oh well.. it was humid like 60% and still was able to run a 14:33 @94mph
that's why I like the meth kit =)
Old May 30, 2013 | 07:05 PM
  #35
Veteran: Army
why? there's different loads on the motor at the track...
Old May 30, 2013 | 08:39 PM
  #36
JMC's Avatar
JMC
25 Year Member
What configuration was the EcoBoost? Do you go past 3rd into 4th in the ¼? I run through 3 gears (Manual Trans). I launch in 4Hi then shift into 2Hi after I get going.
Old May 30, 2013 | 09:53 PM
  #37
twinskrewd's Avatar
update...
Hey Ken just curious if you have relocated your IAT sensor from the MAF to an intake runner so you and the ECM can see Air Charge Temps?
I'm curious as to what the Meth is doing.
Old May 31, 2013 | 12:52 AM
  #38
IR0NS1N's Avatar
That was my thinking in an earlier post. I wonder if the timing needs to kick in at lower iat
Old May 31, 2013 | 09:29 AM
  #39
jemckinney's Avatar
ecoboost is one bad machine with a tune! I would rather put a blower on a 5.0 if I had the option. I had the 5.4 and had nothing but trouble with it, couldn't get a good tune to save my life. I had both a vortech and whipple S/C. I also put in a race built tranny, re-geared, e-fans etc etc and I was never satisfied with it's performance. You gotta pay to play.. good luck to your choice!
Old May 31, 2013 | 05:13 PM
  #40
kens fx4's Avatar
yes I did relocate the MAF..
Old May 31, 2013 | 10:17 PM
  #41
IR0NS1N's Avatar
IAT you mean??
Old Jun 1, 2013 | 07:36 PM
  #42
kens fx4's Avatar
IAT you mean??
yes that's what I mean...
Old Jun 1, 2013 | 11:41 PM
  #43
IR0NS1N's Avatar
Ah ok good lol. I would see What your iat temps are on the meth. I wonder if its cooling to much reducing timing. Justin is a good guy I would data long the quarter mile passes and see if he can give it more go.
Old Jun 2, 2013 | 10:35 AM
  #44
kens fx4's Avatar
that's exactly what he said...
so next race day i'll be data logging..
