thinking of a big change...
thinking of selling the truck and going ecoboost...
last week at the track i got my *** handed to be buy a ecoboost (with only a tow tune) plus a cap and 34" tires..
but any ways..
what do you think my truck is worth.. couldn't fine any like mine that sold.
2004 F-150 (3v) FX4 Crew Cab 4x4
Whipple Supercharger 10psi
SCT programmer (custom tune by VMP)
BBK 80mm Throttle Body
Pacesetter lt headers
3" spun hi-flow cats
Flowmaster race mufler
275/65/20 GoodYear dura trac
2" level kit
power rear sliding window
power window and door locks
gray cloth int.
true blue ext.
20" factory wheels
edge performance gage
3:73 limited slip
145,000 miles
snow perf. water/meth kit (i may keep this)
windsheild is cracked (not in your view)
cab corners are rusted out (can get patch pannels)
a few scratches.. (kids
thanks for any input
Ken
but any ways..
2" level kit
gray cloth int.
true blue ext.
20" factory wheels
3:73 limited slip
145,000 miles
![Mad](https://www.f150online.com/forums/images/smilies/mad.gif)
Ken
![](https://www.f150online.com/forums/members/kens+fx4-albums-my+truck-picture191967-a.jpg)
my best time is 14.22 his time was 14.17 (and this was his first time ever donw the track)
Jason.. if i could get this truck into the mid 13:'s i'd be so fricking happy..
Thanks for the vid. A few pointers for you. Drop that air pressure in the rear tires to about 24-25psi for better traction off the line. Also don't stage with your foot on the brakes and gas. Let that converter flash. You will be better off pulling up there and ldling then when the 3rd light turns yellow mat it. Once you get good at it you can start feathering that throttle a little bit. In other words don't mat it. Go 1/4 throttle to halfaway then WOT based upon tire spin. Reducing tire spin on the launch will pick up your times and traps considerably.
4.11 or higher gears would also help with both wheel spin and pick up.
Also, it maybe his first time at the track, but that is exactly how you are suppose to launch an ecoboost, probably not his first time doing it either.
I watched the video 5 times to be sure of this, and just to qualify, I am not trying to start anything. Ken barely did a burnout, and did not break loose on the launch. The tires might have made one rotation.
Tuning and dropping charge temps would be things to look at. Methanol injection is an option, but so it Nitrous Oxide...
![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
Also, remember, the Ecoboost may have been modified. CAI, exhaust, and tuning can yield up to 100 RWHP.
Ken- Do you have any data or dyno runs? Any idea of what the A/F ratio is or how much timing you are running?
running street tires and a burn out is a waste of rubber.
also i launch in 4hi.. ANY attempt to leave in 2wd will result in tire smoke!
eco boost was stock excpet tow tune.
yeah i've got a few data logs.. (been sending them to vmp as he re-tunes.
a/f as of right now 11.7 (per gage)
