roushcharger with stage 3 cams
Old May 7, 2013 | 04:06 PM
  #46
scobar's Avatar
Crash, what do you guys use for replacement in tank pumps? I've not found a lot of info on this...
Old May 7, 2013 | 04:34 PM
  #47
06 Roush's Avatar
No the blower is not installed. I just did the gotts mod until I do get a blower. I ordered obx headers yesterday. I am going with the hot rod cams, and I am good friends with the tuner and he has installed frpp cams with blowers before and made good power. I will be saving up to get the cams next (probably order them in a month), and by the end of summer I might have enough for a blower.
Old May 9, 2013 | 08:05 AM
  #48
scobar's Avatar
That pump fits all fords then or?
Old May 9, 2013 | 04:51 PM
  #49
IR0NS1N's Avatar
Me personally, I am going to one day get the FRPP hotrod cams. They are for N/A setups but guys with blowers (mainly mustangs) still pick up 25-30RWHP up to 5200RPM. They make erven more power then that up to 7000RPM but our trucks will never see that. Also across the torque band no torque loss over stock cams. They sound mean as hell too. Unless you go built, in that case I would get custom grind cams
Old May 9, 2013 | 09:32 PM
  #50
06 Roush's Avatar
Yes crash! I am going with hot rod cams.
Old May 9, 2013 | 09:46 PM
  #51
06 Roush's Avatar
Old May 10, 2013 | 11:00 AM
  #52
IR0NS1N's Avatar
http://www.youtube.com/results?searc...pp+hotrod+cams
I dont have a link to all the dyno sheets but typical tuned gain was 20-30rwhp at 5200rpm (more at 7000rpm) with torque same as stock cams below peak torque. Sounds awesome too. Lots of blower guys use them even though they are not blower cams. Again if you go built race purpose engine I would go a blower cam with a grind made for the motor. If you just want lope and a little power those are hard to beat.
Old May 11, 2013 | 07:26 PM
  #53
06 Roush's Avatar
I started taking the stock y pipe and manifolds off Thursday afternoon and Friday afternoon. Today I got the headers and am finishing taking off the manifolds (quite a tough task). I will hopefully have it back together by next weekend and be able to get it tuned (that's the goal anyways).
Old May 12, 2013 | 11:06 PM
  #54
06 Roush's Avatar
Didn't work on the truck today since its Sunday and mothers day. I really hope the gains and sound from these headers are worth the time and money, because they are a pain to install.
Old May 13, 2013 | 04:47 PM
  #55
IR0NS1N's Avatar
I felt no difference going to long tube headers. True got a lot louder though. These trucks are to fat for accurate butt dynos
Old May 13, 2013 | 10:35 PM
  #56
06 Roush's Avatar
I got the drivers side manifold and the remainer of the y pipe off today. I also got the passenger header installed. Crash!, I will probably order the cams in a month or so and hopefully have enough for a blower by the end of the summer. Do u guys think it will get that much louder even running the same si/do catbacks? Are those gain numbers before or after a custom tune? (Hopefully get my free tune Friday)
Old May 13, 2013 | 11:41 PM
  #57
IR0NS1N's Avatar
Yes if its no cats extremely loud. With cats just loud
Old May 14, 2013 | 11:05 AM
  #58
06 Roush's Avatar
It still has resonators still loud?
Old May 15, 2013 | 07:08 PM
  #59
scobar's Avatar
Wow, the cam swap looks fairly simple. Too bad the head has to come off for valve spring upgrade
Old May 15, 2013 | 11:28 PM
  #60
06 Roush's Avatar
I ran into a few problems. I need to remove a few studs to get the drivers side header on. How can I get them loose? Used pb blaster, 5mm socket, and locking 2 nuts together on stud. I don't have access to a torch will running the engine up to operating temp help? Also dipstick broke off nearly flush with the block. Ordered a new 1. How can I get the old 1 out?
