sooooo
If all goes as planned I'm taking tomorrow off. Gonna wash, wax, steam clean interior, change the oil, fuel filter, and plugs. Then I'm going drag racing Saturday with a new tune Mike sent me Tuesday evening. Can't wait to see how the strategy plays out along with my mandrel bent exhaust system. Super stoked right now! Wanting that elusive 12.5 run. Mike says there's another 35-40rwhp in the tune but we are not doing it as it could prove fatal very quickly. I did not realize how detuned she was. This new tune has some more timing and a leaner mixture at the start. Up'd the 1-2 shift to 5600 rpm. A few other changes in the mid range as well.
Nice work
OBTW I drive mine almost everyday, have 185K miles and now pullied at 16lbs of boost. Love it
Yep corrected my post. I was so used to it being di/do single with a single muffler lol. What resonators are you running? And did you add them later or when you installed the mufflers. I'm looking at these http://www.nolimitmotorsport.com/ctg...R/prod/VP-1792
Running OBX long tubes with their resonators where the rear cats would be. I also put factory cat grilles over them. Not sure what they do for sound, but I do know that these trucks get real loud with no cats. Tailpipes run out back on each side. L's and HD's both had DI/DO mufflers. I love to drive around, deselect overdirve and let off on the gas to hear the exhaust rumble. Or be in low gear in a parking garage or bridge and hit the gas, the growel is joyful. On my Cobra with sidepipes (no cats or real mufflers) the bridge trick is impressive. Of course with that vehicle I just hit the gas in any gear and let the revs build as the rear tires break loose
Do you have your car featured anywhere online? I would love to see more pics. The 64 427SC is one of my dream cars. Jack Roush has or had one. I got to see it back in the late 90's. I needed a bib to keep up with the
I installed the eaton at 90K, intially at 6lbs then slowly went to 12lbs. At 120K, started getting raw oil on tail gate. So pulled engine down, looked good, except exhaust valve guide which where all worn. The boost evidently hammers the exhaust valves. Installed L steel crank, fordged H beam rods and forged piston. Rebuilt heads and installed with ARP studs for good clamp up. Ported eaton, plenum ten +8 lower. Nothin specials but then this truck is daily driver and has only been to drag strip once on street tires (no traction, so a lot of spinning of 285/50-20's through first and second gear).
WRT Cobra, mines a replica. I built a 351W stroked to 393 ci making about 500hp at the flywheel. At 2500lb vehicle weight and a 3.70 nine inch rear contolled by a true 4 link, its fun to hit the gas and at least go straight, even if the tires are smokin. Basically its straight pipes so it sounds a lot like a HD motorcycle.
