2004 Whipple problems
#46
I know you can't really rely on them but I have used about ever 1/4 mile calculator out there and all of them put me at 12.9-13.1. Using 475rwhp and a 5400lb weight. Now obviously I have done better than that with a 12.7 on fouled out plugs but I really don't see running better than a mid 12. If I do my head may explode. LOL.
#48
So, I finally received an updated tune from JDM and put the stock tires back on. I went from 350 hp/411 tq to 386 hp/450 tq. I'm not terribly concerned about the numbers although they seem low for my mods, but the psi is the concerning part...only 7psi of boost. I verified this with two gauges and looked for any leaks and found nothing. The whipple tech said nothing is wrong because with a 3.0 pulley (10psi) I should expect 2psi drop for elevation (4200 ft) and 1 psi drop for LT headers and free flowing cats. Let me know what you guys think. Also, is there anyone supercharged at elevation that has found similar results? My local dyno tuner says if I want to see more boost I simply need to put a larger crank pulley on, is 3psi drop really legitimate or is something wrong I'm not finding?
#49
Iam at 4500ft at home. I was told 10RW loss every 1000ft.
#51
#52
#53
Lee
#54
#55
