12.7 at 105.7mph bumping the rev limiter
Old Mar 15, 2010 | 12:16 PM
FATHERFORD's Avatar
Originally Posted by Windsor
I don't see how that's possible. My invoice for my 2008 shows a shipping weight of 5,296 and it's a supercrew 4x4.
I did have 3/4 of a tank, also the blower setup adds at least 100lbs, traction bars, bed cover(although lite), me(300lbs), djm lower control arms are much heavier then factory and I'm sure a few other reasons. Only thing removed from the truck that wasn't factory was the front sway bar(40lbs).
Old Mar 15, 2010 | 02:41 PM
Huitt24's Avatar
I think there zero must have been off. My truck weighed in at 5775lbs at SAR and it weighed in at 5800lbs at Houston the two times I went on the scales. The difference was the level of fuel in the truck. I weigh close to 285 so we are close in weight. I would guess you are in the 5300 ball park with your bed cover on.
Old Mar 15, 2010 | 03:03 PM
FATHERFORD's Avatar
I was guessing between 5300/5500 myself.
Old Mar 15, 2010 | 06:07 PM
twinskrewd's Avatar
I would think you would be around 5000 without your wieght included. Right there with a Nightmare. Mine wieghed in around 5600 with half a tank and stock wheels.
Old Mar 15, 2010 | 06:12 PM
FATHERFORD's Avatar
My truck is over 5000lbs I know... Somewhere on here I weighed it when I first got it with some race scales and it was knocking on that door of 5000 stock.
Edit:
When the truck was stock with a 1/4 tank of gas it was 4928lbs. add all that stuff including me above, and my truck weighs 5500-5600 with me in it.
Old Mar 20, 2010 | 12:31 AM
BobFinnell's Avatar
My truck wieghed 6000lbs with a full tank at the county dump and on a CAT scale at the pilot truck stop.(04 supercrew 5.4 4x4)
Old Mar 23, 2010 | 11:47 AM
Z7What's Avatar
BTW I weighed my truck on the track's scales and it said 6300lbs... That can't be right, I need to recheck it.
Yeah, that cant be right. My truck is 6320
Wayne
Old Apr 13, 2010 | 03:06 AM
BlkStang's Avatar
28" slicks is the way to go!!!
Old Apr 18, 2010 | 07:49 PM
UNITY's Avatar
No sir, still the mail order tune....
I think I'm going to go ahead and order my 28" slicks to see if that gives me just enough tire to cross the traps. If not I'll have to pump down to 3.90 or 3.73 Gears.
If you need to go to 3.73 let me know. I have an LSD axle off of my 08' with only 15k miles on it.
Nice time! Does your track require you to cage the vehicle once you hit 12s?
Old Apr 18, 2010 | 10:36 PM
FATHERFORD's Avatar
I think it's 11.50 a roll bar is required.
Old Apr 21, 2010 | 11:28 AM
Grant 218's Avatar
nice times!!!!
Old Apr 21, 2010 | 11:29 AM
Grant 218's Avatar
you were close! its actually 11.49 and lower a roll bar is needed. if you run 11.50's you are borderline lol
