exhast i need help!!!
With the supercharger your getting plenty of air in,,now you need to get it out.
I run long tube headers with high flow cats into an X pipe,into 2 mufflers and 2 pipes out the back.
So it's a dual 2.5" system ( your choice of mufflers and exit anywhere ya want.)
The most important part for making more power is the long-tube headers and high flow cats!
Phil
Phil
I have this setup as well and I changed to 2 magnaflow mufflers 5X9 cas the 14" is way to loud!
I did not!
Only thing that I saw less boost with was the ported heads and cams. About 2 to 3 PSI less.
Phil
Phil
i am thinking about running LT's. im not sure if its worth it. i have shorties right now....
I agree with you on going with two mufflers right off the bat. The sound with my true dual setup is tolerable compared to my original setup. Long tubes, high flow cats, x-pipe, and performance mufflers such as Magnaflow’s are the way to go.
Phil
I've been wanting long tubes myself, however, I don't know if there's enough room to jack up the block with the supercharger in place. There's little to no room between the SC/TB and fire wall. Has anybody done it with the SC already installed?
not to dog on any onese set up, but i was told pacesetters are cheap and wont last more then like 3 years?
weazel, My headers work fine the only thing I dont like about them is the gaskets that come with them other than that they are a great header IMO. for 409.49 you cant beat that!
I got the cats from performance peddler they were about 50 each
http://store.summitracing.com/partdetail.asp?autofilter=1&part=PSM%2D72C2229&N=7 00+4294908331+4294840115+4294806411+4294839039+115 &autoview=sku
