Whipple question
Whipple question
What size injectors do u need to use with this kit? How good is the tune that they send you? what problems have u run into with this kit? How much power are u putting down? I have a 05' 5.4L........
Stock injectors work with the standard 8psi kit. If you want to upgrade to 10psi or more, you'll need to move up to a 39lb injector.
The stock tune is okay, but it will probably be sent with a speed limiter to keep you under 98mph, so be prepared for that disappointment. A custom tune is definately the way to go if you want the most out of the Whipple.
Power with the stock kit will give you around 340-350 rwhp and 360-380rwtq.
Whipple Gen II (Mfg After 1-08)
Does Any One Have The New Whipple Gen II Supercharger On Their F150 Yet?
The New Whipple Supercharger Has A New Rotor Profile W140ax-Green.
http://www.whipplesuperchargers.com/...sp?ProdID=1162
http://www.whipplesuperchargers.com/....asp?PageID=77
If they do come with upgraded injectors, does that mean 10psi is not a problem?
Mark, what have you done to yours? I spoke with a couple comapnies and they told me a boost a pump might be worth getting if I'm looking for 10psi+
This is the claimed hp from whipple on a stock 05 5.4L.........
"With 8psi of boost being forced through the intercooler, the stock engine produces nearly 475HP to the flywheel and 394 RWHP!"
Plus I have 1 5/8" dynatech long tubes with high flow cats and magnaflow catback....
so i think it should be over 400 rwhp and over 440 rwtq but who know right....
