Can my truck handle a turbo?
Old Mar 17, 2008 | 05:26 PM
guite_42's Avatar
Hey, Im looking to put an sts turbo system on my truck within the next month or so but will my truck hold up to the extra power? I have a 99 F150 with a 5.4 l. Its the stock motor and transmission. Its got 35's and 4.10 gears. Will the stock rods etc and tranny hold up? thanks
Old Mar 18, 2008 | 05:59 PM
Veteran: Army
depends on how much boost, how hard you drive it, whether it's intercooled, what supporting mods you add and how it's tuned.
I recomend a pro-M blow thru MAF, 42# injectors, 255lph in tank fuel pump, a good tune and an intercooler.
Old Mar 18, 2008 | 06:50 PM
shifty_85's Avatar
The most that people say you put on a stock motor is 8PSI if you go 10PSI or higher you will deff have some probs. But 8PSI is what is normally said that a Stock engine can handle before and big changes are needed. You will deff need a custom tune if you do add a power adder such as a turbo or Supercharger so your computer knows what to do with the extra air.
Old Mar 18, 2008 | 06:54 PM
Richard D's Avatar
Depends on the boost level and the tune for it.
Old Mar 18, 2008 | 09:31 PM
tj03f150's Avatar
how many miles are on it?
tarajerame is right though
blow thru maf, 42lb injectors 255 fuelpump.
ive got a remote mount on my v6 f150, as long as the turbo is sized properly u wont have any lag or anything.
4 10's might be a little big. i have 3 55's for a supercharged or turbocharged application lots of people run 3 55's to 373's i dunno about bigger tahn that.
Old Mar 18, 2008 | 10:18 PM
built54's Avatar
I Have 4.10's... but with my tire size, that puts me right at factory ratio.
Old Mar 19, 2008 | 10:00 AM
powerdynedriven's Avatar
I am selling my powerdyne and are also going to the sts turbo set up.. Check my sig below but its basically what these boys have allready been tellin u. Although i have been running 10 to 11 pounds of boost for a while now and no problems besides traction issues I also have the 4:10 gear and i really like it. also just got done putting in a fairbanks shift kit 2nd really hits hard. Good luck bruther
Old Mar 19, 2008 | 10:24 AM
guite_42's Avatar
Thanks for all the help guys, The trucks got 90K on it and I think the kit comes with the injectors and and going to them to have it done so they are goin to tune it while im there. Im only planning on running 7-8 #'s of boost on it cause it'll be driven pretty regularly. Hey built54, did you do your custom dash pieces yourself? looks awesome and would like to do something like that to my ride.
Old Mar 19, 2008 | 07:24 PM
Veteran: Army
you'll want to consider a shift kit asap, either a transgo or a factory tech people seem to like both and they help the tranny last a bit longer
