Engine blown....
my pos HIGH mileage 91 ranger with 4.0 and 5spd will stomp all over my truck. stock vs stock and the ranger has oversized tires w/o new gears. why? cause it weighs about half lol. now that i think of it, that rangers pretty quick for an old dog.
i wanna see some smoke JMC!
good job Jmc
better get Neil to fab some pipe so you
can tuck that intercooler up in behind the bumper
before you do any serious 4x4 ing
mitch
mitch
HI!... HA, HA, HA......... JMC, just wait until the X-CAL2, CAT-BACK, and 4.10's get installed in the RANGER.!!!!! BTW my Rangers not light. Weighed in at 4100LBS with me in it and a 1/2 tank of fuel.
I would guess that jmc's truck with him in it and a 1/2 tank gas is 5400#
HI!... Yes but considering that my F-150 only weighed around 4550LBS with me in it, the new RANGER is a pig!!! My "83" Ranger only weighed in at 3100LBS and that was with a 351-W in it. But a lot has changed in the Rangers since then.
Either way JEAN-MARC, I'll just wait until your Manual crap box break and sail to the finish line! BWAAAAA! (JOKING)...........
Klitch,
I am having cooling problems with the engine using the location that I chose. The tanks are positioned across the rad and they block quite a bit of air flow to the rad. I was going to modify the way it was mounted today but it is raining. If it is nice tomorrow I will snap a few of the way I have it. Basically it is resting on the pipes and coat hanger hooks hold it to the rad cross brace. I have a 3 inch body lift so the pipes pass between the frame and the rad.
I needed to cut the brace that comes down to the bottom of the rads support. to make room for the intercooler.
JMC
I needed to cut the brace that comes down to the bottom of the rads support. to make room for the intercooler. JMC
