little boost
Old Nov 13, 2006 | 07:08 PM
F-150 HD's Avatar
Exclamation little boost
i got a ati procher with a supposed #12 pully but im boosting way less than this, plus when im getting in boost my truck is about to shift already. any remedy for this? i got a sct flash programer. any help?
Old Nov 13, 2006 | 07:22 PM
adt's Avatar
adt
Get in touch with either Sal @ powersurgeperformance.net or Mike @ troyerperformance.com Sounds like you need a good tune.
Old Nov 13, 2006 | 07:46 PM
CDB03STX's Avatar
Just asking.....You are putting the petal to the metal...right? Normal driving you want see any boost at all hardly.
Otherwise, as ADT said.
Old Nov 13, 2006 | 07:49 PM
justjames80's Avatar
Check for belt-slip first and foremost. Any black dust around the supercharger housing? If you follow ATI's instructions for tightening the belt you are almost guaranteed to see a lot of belt-slip. What size is the pulley on the headunit? 12# pulley is a 3.40", 9# is a 3.70"
Old Nov 14, 2006 | 12:41 AM
Jordan not Mike's Avatar
If by "want" you mean won't...I respectfully disagree.
I see boost at less than part throttle all the time. Not a ton of boost (obviously it increases with larger throttle openings).
Not at tiny throttle openings, but certainly at much less than full throttle when I'm accelerating.
Now, steady-state cruising, engine is in vacuum, that's normal. And gentle acceleration will produce little boost, if any.
Old Nov 14, 2006 | 08:45 AM
That Guy's Avatar
Not to be insulting here but....are you running an underdrive pulley by any chance? Don't laugh, I've seen it done and taken calls from pissed off people complaining the SC is junk when they are actually underdriving the SC!
TG
Old Nov 14, 2006 | 10:10 PM
F-150 HD's Avatar
whats a underdrive pully? i have the regular procharger set up, um and i have the #12 pully with a sct flash, u think i need another tune?
Old Nov 14, 2006 | 10:58 PM
SCOTTE`screw's Avatar
believe me mikes tunes are the best...so yes tune it right
Old Nov 15, 2006 | 12:35 AM
If you aren't seeing any boost with a 12# pulley, it's not your tune.
The blower is mechanical, just a simple impeller. So the faster you spin it, the more boost it puts out.
It's leaking out somewhere. Make sure your install is good and all connections are tight.
Is your bypass operating correctly?
Old Nov 15, 2006 | 12:53 AM
F-150 HD's Avatar
yeah the bypass blows off, how much is a new blower or a new tune?
Old Nov 15, 2006 | 12:38 PM
If needed, you can get your blower rebuilt by ATI. But I would look elsewhere for the problem.
Where are you located?
Do you have detailed pics of your setup?
Also, your boost will ramp-up to 12psi at the shift point (and a little before). You won't see 12psi at lower rpm and/or small throttle openings.
Old Nov 15, 2006 | 06:08 PM
adt's Avatar
adt
Yep, you won't see 12 psi until you're at the rev limiter, 5200 rpm or so.
Old Nov 16, 2006 | 10:30 PM
F-150 HD's Avatar
i am in hawaii, and i will check the pully's cuz i just seen the other procharger comment on a 5.4..but also i was told that the new kits do not come with a fmu? i have a in line fuel pump should i switch it out for a intank one?
Old Nov 17, 2006 | 05:13 PM
adt's Avatar
adt
The ATI inline pump should be just fine as far as fuel pressure. The only down side to the inline pump is the reliability and the noise, that sucker is loud. Sometime soon I'll make the switch to the 255 lph in tank pump.
Old Nov 17, 2006 | 07:19 PM
For sure, if you have a lot of belt slip you won't see max boost.
Do you see a lot of belt dust?
