ATI Procharger belt issues-F150, 5.4l engine
Old Nov 13, 2006 | 04:43 PM
VasileRT's Avatar
Hi all,
I have been having issues with belt comming off, breaking, etc. I tryed different tension levels on the belt, no change. Anyone, any ideas?
Any input is much appreciated. Thanks.
:confused:
Old Nov 13, 2006 | 05:08 PM
justjames80's Avatar
If the belt is coming off you need to shim the mounting bracket. If the belt is breaking then try another brand of belt. I've pretty much found that is order to get a 12# pulley not to slip requires enough tension that makes belt life relatively short. I'm using Dayco Poly-cogs now and they seem to hold up well. I'm seriously going to start looking into making an 8-rib setup though if a RR pulley doesn't help.
Old Nov 13, 2006 | 07:12 PM
adt's Avatar
adt
The 3 bolts that hold the blower bracket to the block are the ones you need to shim. Generaly one washer on each bolt will do it but when I got my gatorback belt on I also needed to put one more shim on the very bottom bolt to get the pullies lined up. No more problems with the belt wanting to walk off the pullies.
Old Nov 13, 2006 | 07:50 PM
CDB03STX's Avatar
Make sure that the spacers in between the bracket and motor are the same length. I have not had a bit of trouble out of my belt and I don't have the first shim.
Old Nov 13, 2006 | 07:56 PM
There's always going to be tolerance stacking issues with stuff like this. Some need no shims, some need several. I only needed one washer in the lower bolt spacer to get mine to track correctly. If the belt is coming off the front of the pulley then he might need to shim the same way. If it is coming off the back of the pulley then put a washer in the top spacer.
Old Nov 14, 2006 | 11:02 PM
VasileRT's Avatar
2001 F150 Crewcab, 5.4l, P1SC
Thanks a million for the inputs. It seems logical with the shimming. Mine seems to walk off in front about 1.4" then stays there but it damages the belt. I will try different shimming scenarios to line it up.
Best Regards,
Old Nov 15, 2006 | 12:42 PM
Jordan not Mike's Avatar
I shimmed my pullies to fix it on my truck.
Never thought about shimming the mounting plate.
