Cat removal
Cat removal
Is it possible to remove the catalitic converters altogether?? what happens to the O2 sensors? just plug them back in the pipe? Would you need a new tune? Being down in south America, emissions is not an issue here and I would like to remove the cats ...
Thanks for the info.
Originally Posted by mab351
You will set codes for the catalyst monitor and rear HEGO sensors if your truck has standard OBDII. You will need to get the rear sensors turned off, or put in HEGO simulators which seem to work pretty well.
Where do you get the cat eliminators you mention?? That sounds really interesting¡¡¡http://www.ponyexpressperformance.co...iminators.html
http://cgi.ebay.com/ebaymotors/96-07...QQcmdZViewItem
