Pictures of the Whipple up close
Old Nov 11, 2006 | 08:27 AM
mcdover's Avatar
Originally Posted by MeanGene
Also, I have looked all over the net for a good price. Where can I get a good price on the whipple?
For example I am in the process of upgrading the front rotors on my truck. Everywhere you go you will fine the Baer Eradispeed +1 rotors going for $800.00 + dollars. I found them here for much less and only $10.00 shipping. Can I find a similar deal with the Whipple?
Try superchargers4less. When I got mine, they were much cheaper than buying directly from Whipple. Tech support is still provided directly by Whipple.
Old Nov 21, 2006 | 10:12 PM
04LARIATXCAB's Avatar
I finally stepped up and ordered a Whipple- any of you guys running with a boost and/or fuel pressure gauge? if so, what kind?
Old Nov 22, 2006 | 03:45 PM
wstafford's Avatar
I'm running an auto meter elect FP and mech boost in an A pillar pod. Whipple leaves you a place to drill and tap the supplied fuel block.
bill
Old Nov 22, 2006 | 07:19 PM
bill
good deal! thanks!
Old Nov 28, 2006 | 01:00 AM
MeanGene's Avatar
10-4 Looks like you're set. With a tool box like that you might not even need the tools inside!! The only thing I had to scrounge was a low value inch pound torque wrench. Mine did not go low enough.
I have a 100 Ft LB clicker, and a smaller beam type. What was the lowest you had to go?
Old Nov 28, 2006 | 07:08 PM
wstafford's Avatar
Well I'm a bit **** I guess. If Whipple said 25 inch pounds, thats what I did. You can likely get by without a TQ wrench for it and be ok. I had an inch pound TQ wrench but it did not go low enough so I borrowed one from a mechanic friend.
If you need any help, don't hesitate to contact me.
Bill
Old Nov 29, 2006 | 09:41 AM
The Whipple arrived yesterday...It will probably be another week or so before I install but I have a question regarding the spark plug issue, should I attempt to remove the plugs first while the engine is warm or should I just wait til I reach that step in the manual? my truck has 36K miles.
Old Nov 29, 2006 | 12:41 PM
ws6_guyscrew's Avatar
ahhh what a beautiful thing to see when the hood is open
Old Nov 29, 2006 | 06:55 PM
MeanGene's Avatar
How long did it take from order to delivery?
Old Nov 29, 2006 | 07:32 PM
wstafford's Avatar
Given what I have heard on this site, I would soak them overnight (I like PB Blaster), heat the engine up, remove the fuel rails and injectors (for room), then give them a go. Someone else may have a better way??
Old Nov 29, 2006 | 08:06 PM
it took about a week
Old Dec 1, 2006 | 08:52 AM
bill
Where exactly did you tap for the FP sending unit?
Old Dec 1, 2006 | 06:48 PM
wstafford's Avatar
Look at the black spacer that Whipple supplied with the kit. This is what you will drill and tap for the fuel pressure sending unit. I did mine so that the sending unit would point forward like the wiring on the fuel pressure sensor when installed. I'll try to post the picts to my gallery but this computer is kind of stubbon about uploading them to this site. Send your email and I will send them to you.
Bill
Old Dec 1, 2006 | 07:19 PM
wstafford's Avatar
Bill
Nope, something about my browser not acepting cookies
email and I'll send them. Maybe you can post them back to the forum.
Old Dec 1, 2006 | 08:36 PM
Bill
hmmm....I must be missing something, I don't see a black spacer with my kit. Can you send me the pic? greg@iccnola.com
