Long Tube Headers question for Supercharger GURUS, help needed !
Originally Posted by madferraristi
I'm at about 550 using stock manifolds. I know I would have more with long tubes but such is life in the Golden State.
i'm never adding forced induction. i am all motor to 500+ fwhp. i know for a fact the stockers are good to around 370-390 rw, but that's with 11.4:1 and i'm going 10:1.
Your loss, best bang for the buck next to Nitrous and much better drivabilty than a all motor high HP power plant.
How do you figure 500 fwhp?
What is good for 370-390 rwhp stock?? Manifolds? I think you are underestimating them, atleast with FI. There are several L guys running big numbers on stock exhaust manifolds.
i'm not into debating personal choices. i like all motor power. i can always add N2o or anything else. i takes a good bit of design skill to daily drive 525hp N/A. 390rwhp is N/A for the manifolds. i'm losing the 3v heads soon. they present too large of a loss for me to reach the daily driver 500+hp. we all see things differently. all motor is old school. it's more difficult and is more satisfying. look at the cobra 'r'. all motor. very cool. not as fast as a terminator, but more cool none the less. i like to think i'm building my own version of it. under a stock hood none the less.
I seriously doubt 390rwhp is the limit of the stock manifolds. There are a number of things that could be improved before the manifolds and would prove much higher numbers before they are "restrictive" to a limiting sense.
Losing the 3V heads? And going with what? What are you "loosing" with them? They flow much better than 2V heads and require only a little more power to function. The 4V would be nice but you must spin 2 extra cams and an equal number of valves/springs.
For a cool factor sure! I'm not knocking you for that. I'll be rewarding but don't think that FI is "over rated"!
And best of luck in your buildup.
Originally Posted by FATHERFORD
His truck should be putting down way more then that to the ground... I have seen his JDM invoice
Assasinator,
It would be tough enough to build a 500hp N/A motor from a 7+L motor that would pass California emissions, virtually impossible starting with a 5.4L. Remember, we cannot use Long Tubes as they won't even pass the visual part of our smog inspection.
However, with a little forced industion, cams that keep emissions in check, stock exhaust manifolds (somewhat madified) and at least the visual appearance of a full battery of cats, my truck is now right at 600/700, CA smog compliant, I consider that a fair accomplishment.
