10PSI Whipple Dyno Chart
Old Jun 11, 2006 | 07:26 PM
05RoushMarkLT's Avatar
Originally Posted by wstafford
I wiped mine out. Ford has a crappy PCV system, thats all. There is a catch can that can be used to stop the oil vapor from collecting in the intake. I'm going to get one for mine.
I'm going to put the 39 pound injectors in and retune...thats it. I'm not going to stress the internals any further. HEMIs are no longer an issue.
I see a lot about quarter mile times for these heavy a$$ trucks. Anybody had a supercharged F150 in a truck pull? I mean a real one pulling a weighted sled. Thats what trucks do right? We have a pulling track locally here in NE North Carolina. Bring 'em on out...I'll watch!
My truck towed a 6500-7000 pound trailer up through three mountain ranges mostly in overdrive. I don't need a track or times to impress me at this point.
Old Jun 12, 2006 | 09:50 AM
brahmus's Avatar
Originally Posted by Jordan not Mike
That seems low.
I get 318 to the wheels on my 97, and that's with cr@ppy non-PI heads. I've got a Procharger running 10.5 psi. Your numbers should be way higher than mine.
Maybe Raider can chime in here, he's got an L blower on his 5.4L truck and I'm certain that he makes a lot more power than that.
Depends what he dyno'd on. If it was a mustang dyno then that's about right. If not they yes I agree it's low but there are alot of operator factors that can contribute to low dyno #'s.
Old Jun 12, 2006 | 01:57 PM
mab351's Avatar
Originally Posted by That Guy
I believe the Ford Racing plugs are just the Autolite HT0's. Not sure if you are running them already or not. That is the coldest plug that is made in this bastard design that is in the 3V engines. I have a buddy who works for Denso and they do not have a replacement plug and have no plans to make a replacement plug for such a unique design.
TG
Just for info, the Powerworks kit comes with the Autolite HT0 plugs as part of the kit, along with the 39lb EV6 injectors that were used in the Cobra.
Old Jun 19, 2006 | 04:16 PM
rafa26's Avatar
What are you going to do about your drive-shaft as you don't have a speed limiter anymore ? Did you replaced it ?
