cold air for blower...
Old Apr 17, 2006 | 09:03 PM
98Navi's Avatar
I added a pieced together water to air and my intake charge temp dropped from 120ish down to less than 100 at WOT. I idle around 85 degrees. Water to air is the way to go. Fill it up once, and you're done. No refilling, mixing, atmospheric spraying, nothing. Its constant colder air.
Old Aug 30, 2006 | 11:32 PM
rafa26's Avatar
Originally Posted by Matt 05'FX4
I can't see using your A/C to provide cool air for the intake very energy effecient at all. The power gained will be lost turning the A/C compressor anyway so in that case it takes power to make power. Using an injection method as mentioned earlier is a good idea, alcohol and water injection is usually a cheap easy way to get cooler air. I have this kit sitting in my garage waiting for the release of the Roush intercooler. It is a neat idea using CO2 sprayed onto the intercooler to increase its effeciency by as much as 50% they claim. And I do believe it will help a lot because CO2 is VERY cold when sprayed onto stuff. Plus CO2 is really cheap, like 80 cents a pound from a welding shop vs N2O which is a LOT more. It would be neat on race day to freeze the intercooler right before a run. When I get this hooked up, I will do a run without it and with it, and I can look at charge air temps with my X2 and laptop to see if it is really working. Here's a few pics of what I am talking about...
Matt what happened to this project ?
