Prochgarger too lean. what to do?
Old Mar 22, 2006 | 09:32 PM
BullittMcQueen's Avatar
sal is one of the best. stick with him.
Old Mar 23, 2006 | 02:46 AM
justjames80's Avatar
Originally Posted by adt
I bought the SCT Excal 2 from Power Surge Perf. in NY and they're doing the tune. they do work alot with Fords and Prochargers so I'm going to work with them a little more. As far as the A/Fs I was under the truck today on unrelated matters when I noticed that the fuel in line to the in-line pump has a minor pinch in it. Not enough to completely shut down the flow but I think it might be enough to slow it down a little. As soon as I can I will relocate the pump to get rid of the pinch.
How do you have it mounted now? I mounted mine inside the frame channel, not the way ATI has it in the intructions. I used rubber grommets for the mounting bolts so I'd have to practically put my ear to the pump to hear it running.
Old Mar 23, 2006 | 04:17 PM
adt's Avatar
adt
I also have it mounted on the inside of the frame chanel using the rubber grommets. It's slightly behind, and below the fuel filter which has caused as S shape in the fuel in line. At first there was no pinch in the line. Must have happened latter.
Old Mar 23, 2006 | 06:36 PM
Same as mine. Have you tried loosening the hose and twisting it to see if the kink comes out? Might just see if you can run a slightly longer hose...stuff is fairly cheap.
