A "supercooler"
Old Dec 19, 2005 | 09:51 PM
98Navi's Avatar
A "supercooler"
I found this while exploring an idea that came to me on the way home. Using the air conditioning system in the truck to cool boost temps
Cool runnings: Ford's SuperCooler uses cold air to heat up engine performance
By RICHARD TRUETT | Automotive News
The SVT F-150 Lightning concept gets between 50 and 60 more horsepower with the SuperCooler, Ford's john Coletti says.
Not long before the Detroit auto show in January, Chris Theodore, Ford Motor Co.'s chief of North American product development, looked at the SVT F-150 Lightning concept and wondered whether the 500-hp muscle truck's performance could be kicked up a notch.
"Is there anything we can do to really put it over the top?" Theodore asked John Coletti, director of Ford's Special Vehicle Team.
In less time than it takes to smoke a pair of rear tires on a Mustang Cobra, Coletti said, "Yes."
Coletti knew he could boost the truck's performance without making major expenditures or having to re-engineer the Lightning's supercharged 5.4-liter V-8.
He dusted a forgotten item from the SVT parts shelf that had been used on the 1993 Mustang Mach III concept car.
The SuperCooler, as Ford calls it, uses the vehicle's air conditioning compressor and an intercooler to lower the temperature of the air going into the engine.
When air is colder and more dense, a greater volume can
be packed into the combustion chambers. That enables the engine to produce more power.
While the technology is part of a high-profile concept truck, the system can be applied to any engine that uses a turbocharger or supercharger to increase horsepower.
Although different in approach, the SuperCooler aims to do the same thing as a nitrous oxide system, a popular aftermarket addition for enthusiasts.
A tank of nitrous oxide gas is mounted in the vehicle, with a line running to the engine intake manifold.
The gas provides more oxygen to the engine, which allows more fuel to be used in combustion and generates more power.
The gas also lowers the temperature of the incoming air-fuel mixture, making it denser and allowing more to enter the cylinder.
Nitrous systems, which sell for about $800, are enjoying a strong wave of popularity now because of the rapid growth of the sport compact tuner market.
The problem with nitrous oxide is that the tank has to be refilled at around $3.50 a pound. Conversely, the SuperCooler is a sealed system that does not need recharging.
The SVT Lightning concept truck - an early look at the next-generation production version based on the 2004 F-150 - delivers between 50 and 60 more horsepower with the SuperCooler, Coletti says.
The SuperCooler system doesn't need any expensive or exotic hardware, just an additional tank and some extra plumbing. But it works only on turbocharged or supercharged engines equipped with a liquid-to-air intercooler. Much of the hardware is already in place on the current F-150 Lightning and Mustang Cobra. Both are equipped with a supercharger and water-to-air intercooler.
The vehicle's air conditioning compressor chills a tank of glycol - antifreeze - to about 30 degrees Fahrenheit.
When the driver opens the throttle, the coolant in the intercooler, which is about 140 degrees, is bypassed by the chilled glycol.
The system lowers the temperature of the intake air from 120 degrees to between 50 and 70 degrees.
Once the glycol passes through the intercooler, it circulates back into the tank, where it is chilled again.
The system never needs refilling, never wears out and requires no additional maintenance. It also has no effect on emissions.
The four drawbacks are slight:
1. The additional horsepower is not available all the time. It lasts only as long as the supply of chilled glycol.
2. The system adds around 25 pounds of weight.
3. Fuel economy is slightly lower because the air conditioning compressor is running more often.
4. The SuperCooler adds around $750 in cost.
"With a 2.5 or 3.0-gallon tank (of glycol) and an engine our size, 5.4-liters, you are talking about 45 seconds where you have an effective superchilling effect," Coletti says.
continued
Old Dec 19, 2005 | 09:52 PM
98Navi's Avatar
Lightbulb
He says that duration is more than enough since the truck hits 60 mph in around 6 seconds. It would reach 150 mph in about 25 seconds.
Coletti engineered the system so that it doesn't take long for the glycol to get cold again.
"It's under two minutes," Coletti says. "If you think about it, the way we designed it, you can go down the drag strip and by the time you get back to the starting line, you are ready to go again."
Coletti says the standard-issue Ford air conditioning compressor needs no modification.
He says the system is designed so that it gives cooling priority to the truck's cab over the tank of glycol.
The SuperCooler, Coletti says, has applications beyond the high-performance SVT Lightning.
It can be used to boost the performance of small displacement engines, which may have big implications if fuel economy standards are raised.
"It is possible to use the technology in the smaller end of the market," Coletti says.
"Let's say you wanted to replace a 3.0-liter engine with a 1.5-liter engine, you would need to have a boosted engine with a water-to-air-intercooler."
The system also works on diesel engines.
Coletti, who has a patent application pending, says he knows of no other SuperCooler systems.
He says SVT engineers have tested the SuperCooler and verified that it works well under real-world driving conditions.
SVT engineers piled on plenty
of miles on a test mule Lightning last year with no problems.
There are no firm production plans for the SuperCooler. But Coletti indicates it is a ready-to-go system that Ford can roll out quickly to fend off competition, such as the upcoming V-10-powered Dodge Ram SRT-10 sport truck.
"Chris Theodore and I talk about it," Coletti says. "The questions are: When is the right time? What is the appropriate application?
"There are no major obstacles to keep it from production. There is a cost impact. There is a packaging impact.
"But if you need the extra power, it can be done without going in there and tearing up the engine."
I find that quite intrigueing
Old Dec 19, 2005 | 10:03 PM
RGCBSHRTY#1's Avatar
If it ever becomes available in an aftermarket kit, I'll buy it for my Lightning!
Old Dec 19, 2005 | 11:36 PM
98Navi's Avatar
A little more research (before my stupid cable modem crapped out for an hour) led me to some stuff that has been done like this. Apparently, the GMC Syclone turbo had some pretty nifty stuff made for it, and this was one of the goodies. Search for syclone intracooler and it will come up (yahoo or google) A simple Intracooler search will lead you to coolmax, a company that builds massive cooling systems, but they weigh a ton and cost even more
Old Dec 20, 2005 | 12:25 AM
desparado's Avatar
What is the date on this article? I read that either the new Shelby or the Ford GT already is using this system. I may be mistaken, but I know I read about this 6 months or a year ago for some ford vehicle, and it wasn't the Lightning. Sounds like a really "cool" idea
Old Dec 20, 2005 | 01:02 AM
98Navi's Avatar
That article I believe was less than 1 year old. It was supposedly for either an 04 or 06 lightning concept they were working on. Its kinda funny, I was just sitting in traffic riding home, and it thinking about boost coolers, and I was like, why not use the ac liquid line? The liquid line on my old mustang used to all but completely freeze up. That would be free cooling during the summer, and you really don't need it in the winter.
Old Dec 20, 2005 | 08:53 AM
brahmus's Avatar
Already discovered and considered https://www.f150online.com/forums/sh...d.php?t=195645
Looks like the price has come down since then too...
Old Dec 20, 2005 | 04:34 PM
For me I could justify the cost if a couple conditions were met.
1. How well does the kit actually work. It is a sound idea and cooling the charge air to a point of a 50hp increase is a good bump. The difference between a hot summer and cool winter day.
2. What is the build quality? Will it stand the test of time.
I could port my blower and tune it for about the same price. I prefer not to go that route for a number of reasons.
Or a small shot of nitrous woud do it. By the time I buy the kit with a tune, it won't be that much cheaper and I don't want to be filling up the bottle on a consistant basis.
Overall an A/C based cooler is the safest route. On a stock L bottom end I'm all about safety, even if it does cost a little more.
Old Dec 20, 2005 | 04:36 PM
FATHERFORD's Avatar
I'de much rather water/meth inject
Old Dec 20, 2005 | 04:43 PM
98Navi's Avatar
I have read about the water/meth injection, and I just don't care to constantly be filling the tank. When I do get to drive the navi, I drive it hard. I'd have to fill the water/meth tank 3 times or more a week if I drove it 7 days
Old Dec 20, 2005 | 04:58 PM
FATHERFORD's Avatar
Depends on how big the tank.. It's not like water and some meth cost alot either.
whatever floats your boat though.
Old Dec 20, 2005 | 05:01 PM
brahmus's Avatar
Greez Lightning has this on his tricked out L. He is on FTW and Truckblog I can direct you to him if you would like to poke his brain.
Old Dec 20, 2005 | 05:08 PM
Yep. Water/meth=too much hassle for me. Don't care how cheap it is.
Old Dec 20, 2005 | 08:54 PM
BruceScrew's Avatar
I've used the blue windshield washer fluid for the last 50,000 miles - cheap stuff and works perfect - ever look at the ingredients.
Old Dec 21, 2005 | 06:22 PM
98Navi's Avatar
I also don't have all that much room left under the hood for a tank, like no space at all really, and I ain't givin up my washer fluid!
And I'd like to pick that guys brain a little, how about tell me wher eto find him.
