Silly Whipple question.
So I'm reading some stuff on whipplesuperchargers.com... I read the following snip on the site:
So I'm thinking to myself - In theory, then the effect on gas milage during freeway cruising should have little/no effect since the engine is breathing normally, right?
I guess what I'm interested to know is the effect of the whipple kit on my MPG numbers for my '04 F150. I know it would drop in city driving, but since I'm majority freeway miles, would I be looking at a 1mpg loss? 2? 4? Is it just marketing hype?
Thanks in advance gurus!
http://www.whipplesuperchargers.com/faq.asp?faqID=21#21
Our system is so efficient and produces such useable torque, that you are rarely at full throttle for any length of time. When you are at cruise speed or idle, the bypass allows the engine to breathe normally, no boost. Only when you depress the throttle aggressively does the bypass close and you have an instant 6-psi of boost. The combination of our unique bypass valve and reasonable amounts of boost, engine life is not effected.
milage
if i have done the math right
13 to 16 milles to the us gallon
mitch
but iam realistic if you get a honest
15 mpg with a pickup of this weight
you are doing great
anyone who sayes they get more than that i always question
mitch
you are doing great
Re: milage
you are doing great
you are doing great
I know alot of it will depend on my right foot, but I figured after a bit I'll be able to control it.
I get 17 city and 22 mpg highway. I have a 4.6L though. I have gotten as low as 9 mpg due to leadfooting it.
