305/45-22 on 3/5 or 2/3 lowered 12' 4x4?
I'm wanting to lower my truck 3/5 or maybe 2/3 and get some 22" KMC Slides that have 38mm of offset and 6.73" of backspacing. Sooo... can i run the 305/45s or will i need 305/40s? i already posted in the Wheels and Tires Forum and got 1 no and 1 yes then i was lead here by c_ulater
How it looks now.
I think the black will look good with the ingot silver
How it looks now.
With 3/5 drop you'll probably rub with 305/45/22 (32.81" dia.), a 305/40/22 (31.61" dia.) will gain you 1.2" and should clear no problem, but I don't have any experience with backspacing dimensions, so depending how much they stick in or out will affect rubbing while turing.
For a comparison, I'm running 305/40/23 (32.61") with 44mm offset (no idea on backspacing of Saleen wheels) with a 3/5 drop on an FX2 and I rub slightly. I "think" the FX2 has a slightly taller stance than a regular 2WD, so the drop should be very close to your 4WD.
My rubbing is on the inner fender mostly. I haven't noticed the rub on the fender lip in the front, but have seen it in the rear (cutting the tire slightly). The rearend moves A LOT when cornering which I think contributed to it, plus a load I had in the bed before. I'm taking care of the rearend movement very shortly!!
If you go this low, there are some drawbacks. I like the look, so I deal with them.
