23" wheel question
Old Jul 22, 2012 | 11:00 AM
fine_style150's Avatar
Looks really good! makes me wish i didnt get 33" m/ts
I want to see what it looks like with the drop!!
Old Jul 22, 2012 | 11:07 PM
jsvo5695's Avatar
Nice ride!
Old Aug 31, 2012 | 08:56 AM
worm5932's Avatar
Well I decided to go with the 3" springs up front and hope for the best. The coil spacers are being shipped to me right now just in case. Pictures and results tonight I hope.
Old Aug 31, 2012 | 09:50 AM
sub'd, hope your issue free. What setup you using in the rear?
Old Aug 31, 2012 | 02:07 PM
worm5932's Avatar
Removed the 2" blocks and 2" shackles
Old Sep 2, 2012 | 10:32 PM
worm5932's Avatar
Well it all seems to work just fine. End result is 3" belltech coils up front, removed rear blocks and ground force 2" shackles with the shim. Came out to 3.25" up front and 4" out back. The belltech couls are stiff once they compress but aren't bad over normal bumps. When they did the alignment they could only get the camber to -1.5 degrees, spec is -1.1 to 0.6. It drives nice and straight and I'm happy with the look. The rear is still 1" higher but that's ok since I use the truck as a truck still. I put a picture in the first post and have more pictures soon, I have the upper bumper pad off to get repainted right now.
