What Else Do I Need?
If you want to really go low, then your going to have to cut the inner fender structures and fabricate new ones, move the fuse box and other the other parts that are bolted to the inner fenders and maybe even install a Explorer power brake booster for more clearance.
hey man i use to be in the airbagg scene, wish i still was. but everything looked good i would recomend viair 480 compressors very strong, and also a 8 gallon tank youll thank me later. the reason i say that is you will lift the front up and half to wait to get the back all the way up cause you dont have a enough volume of air. what i like is the more ports on the tank the better for whatever reason train horns , air hose's ,ect.... from what i know my buddy has a 98 and we bagged his he did the kp 6 link and it was a very well built kit. but his did not come with a notch he bought the 8pc step notch. another place to check out is suicidedoors.com they have everything youll need for decent prices not the best but one stopp shop.Other than that the front end was simple had to trim a lilttle, i think the bump stop bracket and some other lil things but i hope this helps,hopefully dosnt sound like a run on sentence.....good luck doing everything right the first time will save u lots of money and time
jason
jason
and thats your truck?! i didnt know you did that.
thank you! ill probably mimic that pretty closely. i scrape that crossmember almost daily
actually this picture ive posted before, shows the exterior of the frame rail where the trans crossmember is bolted to the frame. See the vertical silver bolt bracket just above the jack
here's another picture of the internal bracing
Remember when we were talking a while back and I said I was gonna be lower, with more ground clearance?
ahh you got me good. didnt see that comin.cool deal tho. thanks for the pics!
theres a guy that is also a member on this forum and i asked him to send me what kind of set up he had on his truck and instead he gave me a complete list of what i needed..... shoot me an email Blackedoutv6 and ill shoot the same email that he sent me..... ima be baggin mine in the next year or two with the set up that he gave me!! =))))
the email is: Cobrajet0123@yahoo.com
Humm... Someone wants to bag their truck huh?
The KP 6 link will save alot on cutting/welding.
You will need a notch - if you planning on running 24's that will put the rear end housing 1-2 inches above the frame rail. (if your gonna lay frame)
Alter Transmission crossmember (I Did like pat, But i took more off and welded a piece of flatmetal back on mine)
Tunnel Driveshaft - The two frame crossmembers will have to be cut and weld in a round piece of 4 inch pipe, Maybe more. Also the rear of the cab will have to be cut to fit over the pieces of pipe.
Rear end - Will have to be shortend. I had to shorten mine 1 inch on each side. And thats just with 20's 35 series tires.
Front suspension - i bought all new stuff, uppers and lowers. But im sure you can modify the stock stuff to work. Also where the uppers mount to frame you will have to raise the mounting point around 3 inches.
Tie rods- Cut, turned and rewelded. simple fix.
Front inner fenders - Lots o cutting. Even back into the firewall. Move fusebox, and a whole lot of stuff.
Thats all i can think of now. This is all if your planning on laying frame like i am. check thread for pics and whatnot. Link on my sig
ive already notched one crossmember, so ill just have to put a small one in the second one. I didnt know about raising the uppers, im going to be using drop spindles. Oh well as long as i dont have retarded camber ha. I need a new axle anyway so why not get it shortened. Ill probably end up buying tubular control arms just because i like them. How much of the firewall has to be cut?
thanks for the help, ill shoot you a pm if i have any more questions if its cool
for sure, ill give you a shout soon man
If you got questions ask away. But i might not be quick to relply
